Fix Thread turned into Re-build thread! (built rb25 neo)
mrflip69
I wouldn't recommend Zerolift... even if you were local and picking up something free from them!
They d!ck me around for about half a year on some SSR wheels, and supposedly even locals are having problems with them.
Find a reputable seller.
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Why not just get some pistons made. All you need is a flatter top right? You are talking about spending around the same amount of money but going to a stock bottem end or heads that you are not sure will work. They only issues i see about making custom pistons is the top of the piston being too thin or the wrist pin bore being to close the oil ring.
sickness14
Car: 95' S14 SE. RB25 Neo. ARP, Tomei 260's, HX40 Pro, PFC, Synapse, Greddy
Thanks for all the help and support guys.
as for the zerolift place, thanks to the poster but ive already got a neo block set up with ricky at rawbrokerage.
The custom piston deal... theres still too much room for error. id have to have a custom mold made of my head and then HOPE that the piston works. not trying to play games at this point. i want a known good setup and since evidently no ones really done much RB26/NEO stuff before, ill just run an all neo setup. the pistons are not made aftermarket for the exact neo motor.
Im getting my money back from the seller of the RB25 head, he turned out to be pretty cool. he couldnt find the cam caps so he said he'd refund me. im happy. now i can save up some more money and get the short block / pay off my credit card / pay off my shop. Oh and my DD is dying. GAH cant win.
-J
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
hey man i may be inerested in those tomei cams bro...you want to email me a price for them...ill be willing to send you stock NEO cams so the head your selling will be complete...
email me at [email protected]
thanks
Mark
sickness14
S14-NEO wrote:hey man i may be inerested in those tomei cams bro...you want to email me a price for them...ill be willing to send you stock NEO cams so the head your selling will be complete...
thanks
Mark
Thanks mark. im pretty sure im keeping my neo head at this point in the game, but ill definitely let you know if otherwise
sickness14
New precision 880cc low imp. top feed injectors arrived today :p
Modified by sickness14 at 8:00 PM 2/28/2010
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
sickness14 wrote:
:P
sickness14
UPDATE
-Just finished sending raw brokerage a payment for my new NEO SHORTBLOCK! should be shipping sometime soon.
Also got:
-SS braided clutch line-NGK spark plug set
I'll be using my OEM nissan head gasket (new in packaging) for this build as many have reported that they're of good quality and since im using another stock bottom end, with stock bore and all, i could use this HG. saves me $330 for the tomei one. and i already have one.
The last concern of mine is the clutch situation. with a STOCK pressure plate and a 6 puck sprung disc, what kind of power will this hold? at this point im going to put the car together and upgrade the clutch later. my DD is about to die and this car is almost done.
I've also got to order some EV-1 injector pigtails and wire in my resistor box.
-John
Sil240
Car: Nissan S13 "The One Cam Wonder"
Why are you using a STOCK pressure plate?Take the stock PP to a clutch shop and have them upgrade your PP. You have have the Fulcrum moved on it, you can upgrade or double up on the spring plate. Have straps added etc.
Or just buy a upgraded Z32 PP. Cheapest and easiest way.
The clutch is a system.The disc creates the friction, the PP creates the Pressure to hold it to the flywheel.
So your disc is only as good as your PP.
sickness14
Sil240 wrote:Why are you using a STOCK pressure plate?Take the stock PP to a clutch shop and have them upgrade your PP. You have have the Fulcrum moved on it, you can upgrade or double up on the spring plate. Have straps added etc.
Yea its a stock pressure plate that was "modified to work with clutch disc" by previous owner. Since this is a pull type transmission, doesnt it use a different PP than the Z32?
Sil240
Yeah my bad I forgot that the Neo's were pull. Z32 is push.if they already modified the pp to work with that disc then you should be good. If you know anyone with a stock Neo pp then try counting the straps and see if there are two spring discs also the actual plate should be surfaced flat. Stock pp are concave or have a slight grade to them.
sickness14
Sil240 wrote:Yeah my bad I forgot that the Neo's were pull. Z32 is push.if they already modified the pp to work with that disc then you should be good. If you know anyone with a stock Neo pp then try counting the straps and see if there are two spring discs also the actual plate should be surfaced flat. Stock pp are concave or have a slight grade to them.
Here's what it looks like
S14-NEO
sickness14 wrote:
:P
i noticed those injectors are low impedence..just so you know NEO's use High impedence...what reasons do you have for running low impendence?
ive also got a nearly new NEO clutch setup...whast are you wanting to know about it...you interested in it?...i have no reason to hang onto it cause im running an Exeddy Twin Disc
sickness14
most aftermarket injectors are low imp. so you basically have to run a resistor box if you want a decent set. as for the clutch setup, i dont think a stock one would do me any good, but could you look at my pic i posted of the clutch and see whats different about your PP ?
sickness14
Worked on the injector harness a bit. waiting to order some EV1 pigtails ~$35 or so. anyone have any good ones laying around? the ford style ones?
S14-NEO
blah...ive got a set of RC engineering injectors in my car that are high impedence...they are out there..lol...you just gotta look for em...i should be able to snap a pic of it tommorrow (clutch that is)...and ill post it up here for ya.
sickness14
Finished up the injector harness with my new EV1 pigtails
Raw brokerage sent pics of my new R34 Neo block today that just shipped out :p
sickness14
Cant forget the baller' interior modz. the seat covers were a joke, they came with my RX7 when i bought it.
sickness14
l0nestar
2004 Toyota Altezza
Lookin good! (I assume the large hose is for a head-drain?)
sickness14
l0nestar wrote:Lookin good! (I assume the large hose is for a head-drain?)
You're correct :p
mott6904
Is that going in place of the freeze plug? Got any more details about it?
sickness14
mott6904 wrote:Is that going in place of the freeze plug? Got any more details about it?
Yes it is, i believe its a 1" thread 90 degree elbow to -12 an at the oil pan.
UPDATE:
having issues with the GT-FOUR block, and the GTT oil pan & pickup tube... help
Modified by sickness14 at 8:29 PM 4/9/2010
Cjmartz2k
Car: Hunting for a '89 GTR now
Wait, the new bottom end is out of a GT4? Umm, that's less than optimal. No oil squirters and the other problems you are seeing. Also, that bottom end wasn't put together at a factory. Maybe I better leave you with that block and crank before I go back just in case you need it. Still in Charleston BTW.
sickness14
Cjmartz2k wrote:Wait, the new bottom end is out of a GT4? Umm, that's less than optimal. No oil squirters and the other problems you are seeing. Also, that bottom end wasn't put together at a factory. Maybe I better leave you with that block and crank before I go back just in case you need it. Still in Charleston BTW.
WHAAAAAT!?!??
someone chime in. now please is this really true?
RustspecS13
Car: '74 260z and '88 300zx turbo
Not to mention the oil pans are completely different.
So yeah you might want a RWD RB25 block....
Why don't you just get a long block already? I know your having problems that's why I picked up an rb25 to start fresh and get away from my rb20.
~Alex
sickness14
RustspecS13 wrote:Not to mention the oil pans are completely different.
~Alex
dude i just got this shortblock like a couple of weeks ago. this was supposed to be a Neo short block that would just bolt right up with my head, but now... not sure whats up. the block has oil squirters not sure about the rod size (beefy rb26 ones or not)
i see a "sickness14 RB25 s14 part out" thread being created soon
Modified by sickness14 at 8:21 PM 4/11/2010
Cjmartz2k
Well, they didn't make an AWD Turbo Skyline RB25 Neo, but I think maybe they made an AWD Stagea with an AWD RB25 Turbo Neo motor in it. Since the pan is off, look and see if the rods look like little girl rods or beefy ones like the Neo/RB26 rods. Also, you should be able to see if it has oil squirters or not. Don't panic yet, but it's the first thing I'd check. I'm home now so feel free to cal me before 11-11:30 or so, or just in the morning (not too early though) if you want.
Carl H
retracted for misinformation.
Modified by Carl H at 10:57 PM 4/11/2010
sickness14
WC34 Series 2 overview
WC34 series 2 (1998 to 2001) was basically the same as the Series 1. The headlights are slightly different (high beam light moved to the grill). It has the same engine choices, but they are the uprated NEO version of the RB series. The power ranges from 114 kW (153 hp) in the 2l to 206 kW (276 hp) for the 2.5l turbo. 2WD and 4WD versions available. A choice of transmissions is also available: 4 speed auto, 4 speed tip-tronic and 5 speed manual.
