fittings for turbo oil lines
yeahpancake
so ive never looked too much into braided stainless steel lines until i bought one for $20 from some kid. much larger than stock and has a 90 degree bend on one side and a straight fitting on the other.
my question is: what AN fitting do i need to screw into the block and oil feed? since it is a larger line, would i need an oil restrictor or is that only reserved for top mount applications?
the turbo is a GTI-R T28
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
Search I made a thread about this awhile ago. It was recently updated
CakeEater
Car: '93 240SX w CA18, '08 Titan Pro-4X
If you don't want to search:
zerothread/254366
All the info you need.
