How To Make Turbo Lines
Discuss topics related to the CA18DE and CA18DET series engines.
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
With the numerous threads that were on turbo lines I figure I make the all end thread about it.
This is for a CA utilizing a bottom mount turbo like a T25/T28.
Its pretty easy to make. I made these lines for CH187 they ran about $130
Here is what you need.
Those are the Coolant Lines.
This is the Oil line, you could probably make this but I had my hydraulics make one for $18
These are the oil fittings you need. If your non Ball Bearing or if you are and the turbo has the built in restrictor. This is a open fitting that is a 7/16 Inverted Flare to -4AN
If your Ball Bearing but doesn't have built in restrictor than you will need this one. The fitting is a 0.035" Restrictor that goes from a 7/16 Inverted Flare to a -4AN.
This fitting goes on the Oil Block where it turns 90*. This is a M12x1.0 to -4AN fitting. This connects to the turbo oil line and connects to the above fittings.
A little tip when cutting your lines. Wrap the area your gonna cut in Electrical tape, its ok to make it thick. Doing this prevents the line to fray making it difficult to attach the fittings. I use a chop to cut my lines, but you could use a die grinder, table saw or a SS Hose cutter.
After you cut the line, remove the tape and either insert the red part of the fitting or put about 2 loops of electric tape and slide the red fitting on. Once you got the red fitting on screw in the blue fitting. Its gonna be tight so put some force into it.
Repeat the process 4 times. The Clamp fitting will be ALOT easier.
This is what it looks like after your done.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Great write up!
You sure did it for a good price.
The_Chosen_One
It actually came out cheaper because I had left over SS line from my own personal lines I made. But thats pretty much a good estimate.
dat_twinkie
Car: 1992 240sx coupe, RHD conversion, CA18DET power
great writup.. where you get them fittings and ss lines from?
The_Chosen_One
I got them from my local Race Shop
http://www.racepartsolutions.com
however ANY hydraulics shop should have them, call around.
you can also try http://www.makohose.com they ship
mrzabala
Car: 93 Nissan 240SX SE Hatch
Can you make a list for easy ordering/shopping purposes? Thanks.
dat_twinkie
The_Chosen_One wrote:These are the oil fittings you need. If your non Ball Bearing or if you are and the turbo has the built in restrictor. This is a open fitting that is a 7/16 Inverted Flare to -4ANThis fitting goes on the Oil Block where it turns 90*. This is a M12x1.0 to -4AN fitting. This connects to the turbo oil line and connects to the above fittings.
i couldn't find these..
The_Chosen_One
some thing like this?
Quantity Item3 90* -6AN Fittings3 M14x1.5 to -6AN1 EZ-Clamp -6AN4FT -6AN SS Hose1 90* -4AN Steel Fitting1 Straight -4AN Steel Fitting9" SS hose -4AN1 7/16 Inverted Flare to -4AN restricted or open depending on turbo1 M12x1.0 to -4AN
The_Chosen_One
dat_twinkie wrote:i couldn't find these..
The gold fittings can be found here at ATP
Unrestrictedhttp://www.atpturbo.com/Mercha...e=FTG
Restrictedhttp://www.atpturbo.com/Mercha...e=BCS
The Blue fitting can be found at jegs, anplumbing.com and summitracing
anplumbing.comPart# 9919BFE
Jegs.Part# 361-9919BFE http://www.jegs.com/webapp/wcs...79_-1
Summit RacingPart# EAR-9919BFEERLhttp://store.summitracing.com/...w=sku
The Big Coolant fittings for turbo and Block
ANplumbing.comPart# 9919EFH
JEGS.comPart# 361-9919DFH http://www.jegs.com/webapp/wcs...92_-1
Summit RacingPart# EAR-9919DFHERL http://store.summitracing.com/...w=sku
r34 gtr
Car: 98 Nissan Frontier XE 4x4
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
you are quite the sexy beast. quality writeup!
dat_twinkie
thanks the_chosen_one.. i'm going to get these really soon
The_Chosen_One
r34 gtr wrote:you are quite the sexy beast. quality writeup!
I aim to please my sex kitten
r34 gtr
me-OW!
mrzabala
The_Chosen_One wrote:some thing like this?
The_Chosen_One wrote:The gold fittings can be found here at ATP
Yes, thats great. That should be added to the article. Ask one of the mods to add that lists. It helps people get the parts and follow your diy better. Oh, and maybe catergorize that list for each turbo line for user friendly.
Modified by mrzabala at 11:39 PM 5/31/2007
ragenasian
Car: AE86 w/CA18DET
R34 gtr you got issues man
Nice write up. Definately something to think about now.
rico05
Car: 1992 RMS13 w/ CA18DET
Nice, but Taka sells premade lines for nearly the same price. After making my oil cooler, I'm not too sure I want to go though the drama of that again, lol.
I did just replace my coolant feed (metal line assembly behind head) with a single SS braided teflon Aeroquip hose. But that was because I was tired of the unused vac line assembly attached to the stock line.
mrzabala
Well benefits of this is you will become better at making lines and be able to do lines for other places like fuel, water, and oil around the engine.
HPR
Car: 1990 Nissan 240SX
great info! I have some n00b questions though... will those fittings work on the SR20 as well (S14 to be exact)? and how do I know if I need a restricted/unrestricted fitting for the oil line? I have a GT28RS. I think I need a restricted one from what I've searched.
capowered240
Car: 90 240sx
What about the oil return?
The_Chosen_One
HPR wrote:great info! I have some n00b questions though... will those fittings work on the SR20 as well (S14 to be exact)? and how do I know if I need a restricted/unrestricted fitting for the oil line? I have a GT28RS. I think I need a restricted one from what I've searched.
Those fittings should work on the SR20 S13 possibly S14 as well, I believe the S14 requires 1 more 6an fitting.
As for restrictor fitting, look at the turbo where the oil feed line goes, if the hole is extremly tiny than it has a restrictor built it, it should look brass in color. If its a decent size hole than it requires a restrictor this is for BB turbos. If you have a non BB turbo than dont worry because the block has a restrictor in that 90* fitting.
capowered240 depending on the turbo but usually a bottom mount turbo you can get a special oil return flange that lets you use SS lines which will be 10AN or 5/8" hose.
themadscientist
I can't believe you just laid those lines on your paint raw like that
The_Chosen_One
themadscientist wrote:I can't believe you just laid those lines on your paint raw like that
its all good this is what my hood looks like.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
are those **** stains?
ch187
Car: 90 CA 240sx
i missed this thread.
im the one he made them for and i love them. makes swapping turbos a 45 minute job.
and julian now that i know i have a bb turbo do i really need the restrictor?
The_Chosen_One
ca18datsun510 wrote:are those **** stains?
those are burn marks from the engine bay catching on fire.
jt15833
Car: 95' 240SX
So the female oil connection on the block is M12x1.0 and on the turbo is 7/16" ?
If I scrap the water lines and am happy with the oil return (return should be fine ya? A new rubber hose w/ good clamps?) I can just the the 9" SS line and nothing else?
I called a supply shop they quoted me $12.50 woot!
biosehnsucht
if you decided to scrap the water line, which I wouldn't, you should at least cap off or plug up (non destructively) the inlet/outlet on the turbo, I'd think.. don't want crap getting in there
Chinamandrift
Car: ca18det powered ae86
great write up ....this should be stickied .......super useful ...i was about to order taka lines.....but the experience to make them your self is so much better
skdline63
iv got a Gt2876R turbo, im going to top mount it do i need the restrictor in the block or do i pull the out and run a new braided line from the block to the oil feed on the turbo and just rely on the restrictor in the turbo? thanks
jt15833
Car: 95' 240SX
Are the 7/16 to -4 AN fittings brass? Isn't brass frowned upon as a material for pieces that will see vibration?
Return to “CA18DE / CA18DET Forum”
