JETPILOT wrote:First.... a set of slicks with stock (non adjustable front camber) and OEM pads won't allow you to take adavantage of the benefit slicks or even a semi slick tire will offer.
It won't allow one to take full advantage of all the grip in a tire, but that could be said of even a good street tire as optimal alignment settings for racing and street car use are not necessarily the same. However, a sticker tire will still provide more grip. And that still typically translates into faster lap times. An exception might be if the suspension geometry is so mismatched for the additional load that nearing the new limit causes some really undesirable behaviors.
There isn't much reason the OE pads wouldn't be able to provide enough clamping force to lock up a slick. The general exception would be if fade occurs, but that's ultimately a braking problem, not an issue with the tire directly. But a slick will allow a driver to decelerate faster which could translate to higher peak brake temperatures.
But to be clear, Good performance street tires should be fine for the track. You may not be as fast, but any driver can still have tons of fun working within the limits of a car's handling capabilities.
JETPILOT wrote:Second... You can't take a set of OEM pads and run them on a road race course and expect them not to overheat and fade.
Depends on the course really. Some courses are much more demanding of brakes than others.
JETPILOT wrote:DO NOT put silicone brake fluid in the car. You will be replacing the brake system. Type 4 is what you need.
Agreed. Especially with ABS cars as activation of it can cause the fluid to become aerated. DOT 4 is usually sufficient for most people, but they also sell Glycol based Dot 5 (dubbed 5.1) for those that truly need a brake fluid with higher boiling points.
JETPILOT wrote:My advice is not to listen to most people. Most people have no idea what they are talking about. Show up to the track with everything you can afford to put on your car. I showed up at the track for the first ime in a 670HP twin turbo Z with every mod you can think of. My first track eperience was amazing considering what my car is now capable of.
I disagree. Dumping money into a car without seeking to address specific issues can simply be a waste of money. Unless one gets lucky enough to work with a shop that truly knows what they are doing, then the shop will likely put on whatever it is you want or will make them the most money.
Many handling issues can be addressed with minimal mods. My first track experience involved a heavy amount of terminal understeer. A subsequent inspection of my tires after the first session immediately told me I needed more negative camber or less body roll. I already had stiffer anti-sway bars and I wasn't willing to lose much more comfort. I upgraded to adjustable camber plates before the next event and dialed in about 2 degrees of negative camber. Handling became quite neutral after that. I didn't need to have a huge investment of money to get an enjoyable experience at all.
You could potentially get higher limits out of a car by doing so, but that also means you have a new driver exploring higher limits. May be okay for some, but not for others depending on a person's natural driving skill levels.
spitalul2bad wrote:Well... I have very little video footage of my runs. After a couple of laps I wanted to film one and went slower, however, at the end of it, the track marshals forbid me to film again since I did not use a special auto tripod or camera mount and holding a camera (by the passenger, of course) was too dangerous. So... just one short, SLOW lap.
A camera mount would have been ideal simply for the fact that we can not see what the car is doing. I couldn't tell if you were overstering ot if your passenger was moving.
However, from the sounds I was hearing in the video, you may have been overdriving the car. Again, it was hard to tell visually what weas happening, but I saw areas that looked like you had a lot of understeer and others that looked like you had a bit of oversteer. Best solution for either is to actually slow down a bit. Get the car's speed down a little bit more before entering the turn. To avoid feeling too slow, brake a little later (work up to this as you get a feel for it) and you'll actually start turning your car deeper into the turn. Then, instead of aiming for the center of the turn, aim for a point a little further up the turn. Basically you want a later apex. The line that this creates (assuming a constant radius turn) is sort of an outward spiral where it starts tight and broadens as you exit. This will help get the rear around a bit and allow you to get on it sooner, which leads to faster exit speeds. That white civic or whatever it was in front of you near the end was pulling away because he had much better exit speeds.
The line you took was a gradual move towards the inside of the track, then you followed the inside and then exited in more or less a constant radius until you got to the outer edge. The point of an outside-inside-outside line is to create a bigger turn. Use as much of the track as you can. Most of the time, you were aiming to the inside of the car in front of you. Assuming the car in front is driving a decent line, your car should always be aimed pointed to the outside of the car in front (except maybe when passing). To try and compensate, you tried to exit faster by gassing it more. Most cars will terminally understeer. Especially if you've already set up your exit radius and are trying to exit it faster than physics allow. The way you enter a corner has a profound effect on how you exit. The simplest discription I've heard of is "slow-in, fast out. "
Next time, try finding a good driver and imitate their line. You may even try following a FWD car with a good driver. FWD cars tend to require a flatter exit to avoid understeer. It would quickly get you a good feeling of what I'm talking about. You can simply adjust from there to determine what seems to be the fastest way in and out. This could relate to your braking issues as well. Aiming towards the inside of the track too early will mean you have to bring your speed down more to be able to make that turn (your effectively creating a turn as tight as the track). That means you also end up using the brakes more. The driving lines racecar drivers use basically try ti keep momentum up. Keeping momentum up minimized brake usage.
On that note determine what kind of brake fade you were experiencing. If the pedal remained firm, you have pad fade. Coupled with the tips above, if you stil experience fade, a better pad may be in order (one with a higher operating temperature range). If your pedal sinks, then your fluid is boiling. Better fluid can help, but make sure its not a heat capacity issue as well (rotor size). With OE/street pads though, typically the pad will fade before the fluid boils.
As you get better, you'll start adding in trail-braking and really brake deep and still get that rear end around enough to exit with decent rear tire slip angles.
Lastly, I don't know if you are driving a manual or automatic, but if its a manual, learn to heel-toe. It seems you were shifting a lot mid-turn. You should be in your exit gear before entering a turn in most turns. If its an auto, use the manual mode and downshift as you are braking for a turn, not in the middle. Driving smoothly is a huge step to driving faster.
