spitalul2bad wrote:The last couple of days, I've been hard at work on the car. I talked to the guys at the dealership and they seemed pretty good, especially when letting me take off all the aftermarket parts I got on the car and putting the OEM parts back.
Why?
It seems that Nissan thought enough of this engine failure that they don't believe it. The do not believe a VQ35DE would've melted its own piston, killed its valve, rod, messed up 3 others and punctured the block in two places. Although it did.
So, they are sending a specialized comission to look over the engine and determine if they'll cover it under warranty or not. They are actually paying for a round-trip FLIGHT for an entire COMISSION to see what went wrong.
And I'm sitting here asking myself... WHY?
I think there's 3 possibilities:
1. They simply don't believe my dealership and think they're covering up something. Which they are - my mods and being on a track when it happened.
2. They think I supercharged or turboed the car, and want to inspect the engine to see if I am lying to them AND the dealership with my mods and making them pay for my new engine.
3. They are worried that this will happen again, or it may HAVE happened and they think it's a build-quality problem on all VQ blocks. Maybe they are gathering data for Nissan, for an eventual recall on something.
In any case, I took down my mods, got them home, car is at the dealership, they won't blab about anything, hopefully I'll get a new engine under warranty. The Nissan comission is coming tomorrow. Hope it goes okay.
P.S. If I'm doing bad by keeping you all up-to-date with my engine stuff, just let me know and I'll stop.
Generally speaking they as an OEM are responsible for their vehicles under all types of conditions. They want to check it and make sure there isn't a problem with the motor under local conditions (ie regional fuel). If there is they can adjust the tune on cars for your region with a ROM update.
Unless there was a mechanical reason for failure (bad metalurgy in the piston) it was probably something to do with the factory tune running lean with your mods. Even if they do warranty your motor and you get the car back, you'd be best served by getting a solid and safe tune for your car.
Under hard abuse, you need to make sure you're not only running a safe AFR, but you also need to make sure you're running enough fuel to keep your cylinders cool. Two things you can do are add octane (above the recommended octane for your tune), add fuel, or add both.
Obviously we offer tuning and datalogging for your car, so I'm a bit biased. But we also support through Nismo, all the north american independant SCCA and NASA race teams.
JETPILOT is also very knowledgable and is pointing you in the right direction on your brake modifications. You don't need the ST60's unless you're doing endurance racing, the extra weight isn't going to help your handling any, and the ST40 has plenty of surface for a car in your weight range if you're using your brakes properly.
Let us know how it goes!
