they do have a "dual exhaust" but not a "true dual exhaust". After the first 2 primary cats, the exhaust piping snakes around a bunch and then goes into 1 pipe with the secondary cat there. from there it's 1 pipe to a muffler which has 2 outlets. True dual is 2 pipes the whole time...mrodrig2 wrote:All 3.5 Altimas have a "dual" exhaust simply because it's a V engine, albeit they do not have straight pipes which are pretty much never stock because of noise. The 2.5 has a "fake dual" exhaust in the sense that there is only one actual exhaust output being split up to 2 mufflers.
Im telling you, this bastard is going to be loud as all hell. Pretty raspy as well.mrodrig2 wrote:albeit they do not have straight pipes which are pretty much never stock because of noise.
250 only ?!?Altimacoupe501 wrote:Well I went and had a buddy of mine look at it and give me a rough quote, he said about $250
This!Ranga14 wrote:Do you have any photos of your undercarriage and the piping we could see?
You must not understand much about exhausts to know why they connect the 2 exhaust outputs and why it's still 2 separate streams whereas what OP was talking about is putting on straight pipes like a truck.Hussain wrote:they do have a "dual exhaust" but not a "true dual exhaust". After the first 2 primary cats, the exhaust piping snakes around a bunch and then goes into 1 pipe with the secondary cat there. from there it's 1 pipe to a muffler which has 2 outlets. True dual is 2 pipes the whole time...mrodrig2 wrote:All 3.5 Altimas have a "dual" exhaust simply because it's a V engine, albeit they do not have straight pipes which are pretty much never stock because of noise. The 2.5 has a "fake dual" exhaust in the sense that there is only one actual exhaust output being split up to 2 mufflers.
No one has done it before. It may be a little difficult because of the way the piping snakes around (not a whole lot of room). good luck! after I sound deaden my car I plan to just have a magnapack resonator.
I can see that there was a misunderstanding, however there is a better way to handle things.mikethemike wrote:I dont think Hussain was the one instigating it.
