First True Dual Exhaust A/C
All things Altima Coupe.
2012NismoCoupe
Car: 2012 Altima Coupe 3.5SR
Super Black/Black Cloth
CVT
Stillen Cat-Back Exhaust
To clarify, Dual exhaust would be the bottom one in this picture. The top one is not dual exhaust. The top one has dual tail pipes, but not dual exhaust.
I had dual tail pipes on a 4 cyl Mazda 3, but that's not dual exhaust. Also, just because an engine has 2 banks, doesn't meanit has dual exhaust if it merges at some point. To clarify that though, an "X" pipe or "H" pipe is not a merge, but simple a crossover to keep backpressure the same, it is the same reason that manufacturers put on an exhaust like the top one pictured, to make cylinder backpressures equal. But, the H & X crossovers work without actually merging the 2 air streams into one, where as that's what the merge (top picture) does, it makes 2 seperate streams into 1 stream and that is very unefficient, which is why aftermarket exahust exists in the first place.
P.S.: Picture is not nissan, it is Ford Mustang I think, but still relevant.
