So what's the first mod you ever did to a car?
Mine was to a Renault R12 P.O.S. It was my buddies car and we cut a hole in the hood to make a forced air induction hood scoop.
We cut a big coffee can in half and used the metal as a frame for the bondo scoop. Then we took a vacuum cleaner hose and and wire mesh (to keep the leaves out) and mated the hole up to the carb. It worked as well as you'd expect a coffee can, bondo, vacuum cleaner hose hood scoop to work.
First mod to the S13 was new tail lights.
zerothread?id=191094
