ZL-Auto wrote:The injectors came with billet "plates" that the injectors sit in and the "plates" fit into the manifold and allow for a proper fitment of the injector. I did not have any issues with installing them.
See, now that is nice! I ended up getting my manifold modified below to make them work:
ZL-Auto wrote:Hump in the power curve is caused my running such a low Fuel Pressure. the car literally is running out of fuel on the high boost setting. And obviously if youre running out of fuel then yes it will start to run leaner since the fuel saturation is not where it needs to be. The power curve etc will be different when the car is running 3.5-4bar of pressure.
Just set it at 3 bar or 4 bar. I would say use 4 bar for your power. No reason to keep switching back and forth...any fuel not used goes back into the tank anyway
ZL-Auto wrote:I agree with Codyace that most injectors do flow variable on their pressure. but not all injectors are "rated" at different bar of pressure. Standard measurement i believe is @ 3bar of fuel.
Yep. 3 bar is the standard.
ZL-Auto wrote:When my AEM tuner ordered these, he wanted to be able to run many different fuel setups less fuel for road course lower fuel consumption, and higher fuel consumption for drag race etc, They are dependant on fuel pressure.... with 2bar of fuel being minimum you can run with these. And as told they are variant BTW 600 & 1000. They can obviously custom build a set of injectors, they do not have to be exactly what you see on their website.
I have NEVER EVER EVER heard of aany tuner adjusting fuel pressure by means of tuning. That's almost crazy...
Road racing less fuel? Forget about it. That fuel will help keep your cylinders cool, and running optimally. The last thing you want is a lean car at the end of a 1/2 hour session...
Again, I say use a 4 bar fuel system (you'd have essentially 72lbers then), and use selectable maps instead of playing with base fuel pressure.
