im using the q45 maf clip.. its a semi 4 wire.. black/white and a third wire that is a black and a white together... im gonna call my local infinity dealer to find out what wires are what so i can hard wire it.. also with the SAFC.. i can change the sensor type to match the q45 maf..
i ran a 12.9 with the t3/t4 and a 12.5 with the 60-1 and picked up 2mph.. t3/t4 is good if your not gonna boost a whole lot(8-12 range) but for higher boost.. the 60-1 is gonna make more power..
t3/t4 specsCOMPRESSOR SPECS:.50 A/R HOUSING50 TRIM WHEELTURBINE SPECS:.63 A/R HOUSINGSTAGE 3 WHEELthe t3/t4 on the custom adapter plate we made..
http://www.lvdr.net/250GTS/smIM002983.j ... 002992.jpg
60-1 specsCOMPRESSOR SPECS:T04S housing.70 A/R housing60 TRIM wheelTURBINE SPECS:T3.63 A/R housingHIGH FLOW 76 TRIM stg 3 wheel
