FINALLY turbo charge i got a dyno video
Chezedik
Car: 1991 Nissan 240sx
I hope you are talking to the truth, because I was not knocking, I think it is a decent setup, but the AFRs definately need some work. In the mean time, I would turn down the boost until you can get at least some 480s. Then see where the turbo maxes out. After all, better to run rich than not at all.
Jookmasta
ur safc numbers are kinda weird IMO, seems that ur tuner tuned it for boost ALL the time. i would think that ur low map should be somewhere near the -25 range for 1K-2K. the way it is now would seem that its super rich. but if the wideband says its 14.5 when just cruising, then i guess thats what it is. personally i would also turn down the boost or purchase some larger injectors immediately. ur also nearing the max point of the stock maf so i would also start saving for a z32 maf if u plan on turning up the boost a little. awaiting the graphs patiently............
