Are you talking about the dust cap?
If so, a flathead screwdriver you don't care about and a hammer are the only way it's coming off. I remember the first time I took mine off it was an absolute bear. The best advice I can give you is to strike, pry, rotate the hub, and repeat. By working your way around it will come off more evenly. If it goes cockeyed or crooked it becomes more difficult. Which #10 screws around it did you removed though?
If it's not the dust cap, can you find a picture of what you were looking at, or describe the steps you took to get to it?
Oh, and do you have 2WD or 4WD? It probably doesn't matter but it may.
