Nice!
Driving around with an open downpipe is quite fun.
Chris28 wrote:Yeah, it's ECU Talk software. It's a consult to USB cable, plugs right into the laptop. You can check and clear codes, view any available sensors, and if you have Calumsult or Nistune you can grab the .bin file and take a look at your tune. Since it's a read-only chip you can't edit anything but it's great for troubleshooting. Not sure if s14's have a consult port though, it might only be OBD.
I've been blocking off my EGR with an ISIS blockoff plate, even after using rtv it didn't seal. I put the stock housing back on with the paper gasket and got it to seal this time. As far as the fuel pump I've been meaning to hard wire it for a while, I guess now I have a reason to do it. The 12v switched power wire isn't shorting so I'll use that to trigger the relay and run a new wire straight from the battery to power the pump. I still want to find the short in the fuel level wire, screw not knowing how much gas I have. If I have to I guess I'll run a whole new wire from the cluster to the pump.
