i like rev!Carl H wrote:lol reason it feels like it isnt pulling hard is becasuse it isnt!should have stuck with the rb20, its loads more fun to drive :p
Dude b4 my RB started to leak/loose boost??? (Still haven't figured that out yet...) I had it bumped up to 10lbs, and GODDAMN! That was effin scary! I kicked the *** end out in almost every gear! Gotta love that R33 Diff!Kansei240sx wrote:Drive your car untill you hit rev cut so you know what the thing sounds like untill it wont climb revs anymore... Thats the problem with RB25's people dont realize.
I thought my car was slow as hell untill i wired up my SAFC2 and got if for pure analyzing purposes for RPM's, and other sensor readings, and let me tell you i've been shifting at what i thought was 6700 was actually 5000, so i hit up 6900, and it pulls hard as ****.
I just dynoed my RB25DET on 8psi, and on a boost leak that sprung out around the FMIC pipes, and the bov, and also the gasket around it that blew, i made 236 rwhp, and around 240tq with a solid 11.1 afr across the board. I got back home, fixed the boost leaks, and im getting a new BOV, but i fixed the air leaks around it, and oh my god... It is so godamn fast and pulls so rediculously hard i cant believe it.
Its like my friends SR20DET, his car feels and pulls harder than my RB25, but every time we race, i pull him so many cars. Its his lightweight flywheel that makes me feel like its going becuase it builds revs faster, but the RB25 just makes a ton more power and Torque than the RB20 and SR20. As far as im concerned there isnt any HYPE about the RB25... if anything thats to be said for RB20's with all the people i see ****in driving those here in these parts... i mean theres more RB20's than SR's its rediculous.
Yes check your timing...armysweitzer wrote:check your timing.
Haha tell me about it R&R no **** mine does that like hell, needs a tune!Carl H wrote:orange mark on the crank pulley is 0 degrees then to the right every notch is 5 degrees...set it to 15 and go from there, the black smoke is proly the classic rb25 R&R (rich and retard).
Hmm so stock it is set to 15 degrees? If so then yes it is R&R because my friend when he checked my timing did retard it a degree or too. So thats probably not helping. Well good to know this might not be as bad of a situation that I though. *crosses fingers*Carl H wrote:orange mark on the crank pulley is 0 degrees then to the right every notch is 5 degrees...set it to 15 and go from there, the black smoke is proly the classic rb25 R&R (rich and retard).
There's your problem. Get an adjustable FPR, you're blowing smoke cause you're super rich and it feels slow cause it isn't running right. Like said earlier R&R!!!!gomer23 wrote:Yes I have a Walbaro 255. I have not gotten the Nismo FPR yet because I wanted to get it running good before I messed with that at all. That is on my list for the next thing to get though ha.
