Battery > 30amp inline fuse > 30 amp Relay (switched with a 5amp "add a circuit" on the fuelpump fuse) > fans.Florida240sx wrote:How you got your fans wired??? I got mine as a direct feed and off a toggle switch....
I did say the fuel pump was just for the relay switch...kjlindgr wrote:If he wired it right, the only power the fans are drawing from the fuel pump is to trigger the relay = next to nothing.
Don't be a n00b, you really don't know how electrical systems work do you??..wild_maxx wrote:another bright idea... run your 2 fans off the FUEL PUMP FUSE!!! hopefully your pump doesn't get short of power while your in boost... or say goodbye to your motor.
You should run the power for the fans into the ignition source so the fans work while the key is on and its not drawing power from one vital part of the fuel system.
SeanC wrote:this thread is about my car finally being boosted hence the title. when did anyone ask about your car? NEVER.
good point man! The setup looks awesome. You going to paint the pipes? Maybe i'll see ya at some of the seattle car meets.SeanC wrote:this thread is about my car finally being boosted hence the title. when did anyone ask about your car? NEVER.
Which track you going to?If it's Bithlo we should get a bunch of 240's out there.Florida240sx wrote:Come out to the track on Friday...... I'll be there
No.. but you should have an inline fuse on that power to the fans because if something shorts out you might burn up the fans.Florida240sx wrote:Am in danger with my fans?? I got them as a direct feed off my battery. To a heavy duty toggle switch..... 14ga wire from battery to toggle to fan and direct ground to the battery...
Nope your fine with that setup. I was just saying that its not a good idea to run anything off the fuel pump fuse because its a pretty important part of a turbo system. I am sure kenrik knows that and he seems to have it all figured out. now lets all get out of his thread.Florida240sx wrote:Am in danger with my fans?? I got them as a direct feed off my battery. To a heavy duty toggle switch..... 14ga wire from battery to toggle to fan and direct ground to the battery...
