Finally Back together...Bogging under boost now
2FourTee
Car: 96 240sx - Supercharged ka24de
240sxOwner wrote:not a rising rate....I am going to borrow a wideband if i can....Is it possible that my stock maf could be maxing out at 7psi?
AT 7 psi??!! .... I guess it's possible, but doesn't seem very likely. I've seen lots of people run 7 psi on the stock MAF. Maybe somethings wrong with yours, though.
240sxOwner
Car: 93 240sx
The maf is brand new...not even 5K miles on it
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
"i adjusted the distributor today and retarded the timing some more...no more bogging. BUT, now abouve 5K i have a rattle and it sounds like timing chain popping...but everything is brand new...I remember on my last ka...when the timing was advanced for a little extra kick, it did the same thing...Any Thoughts?"
Sounds like detonation to me.
How do you not know what kind of ECU you are running? did you buy the car with the Turbo on? I would do some research into your fuel and timing control and like everyone else says, Get a wide band
