Devious can you flash turbo Ecus? I would pay you good $$ to flash me a chip for 370cc injectors and a map for a boosted KAdeviousKA wrote:Sounds like its going too rich into boost.
What ecu flash is it? Have you run it previously?
do you have any links to sites with more information about this? might be something i want to look into in the future..deviousKA wrote:I sell hardware and on the spot tuning only, no mail order turbo tunes at this time.
You can buy a daughterboard from a variety of places for $50-80, and then a burner for $50. You can then burn the file that redss has set up for ka24de-t and posted over at eccs.hybridka.com. Thats your most affordable solution, and very easy to do.
A daughterboard installed into an ecu with any given tune is going to cost you twice to three times as much, and doesnt include the equipment to RE-tune it like the option above.
Yes im pretty sure you're right..anyone else know how to kill a few psi of boost off?240sxOwner wrote:I though it couldn't be adjusted w/o another spring
That still what my guess is. Is the bogging consistent with the weather or any other variables?240sxOwner wrote:not a rising rate....I am going to borrow a wideband if i can....Is it possible that my stock maf could be maxing out at 7psi?
