HighwayStar22 »
https://forums.nicoclub.com/highwaystar22-u7637.html
Mon Nov 17, 2008 2:17 pm
Hey guys, and girl. I'm almost done my CA and I have a few small bits to square out before I drop it in my car. I need to purchase a clutch and a manifold and then it's all done besides the wiring job on the motor. Here's what I have so far. The longblock is assembled now. I just have to attach the manifolds and flywheel. All the OEM stuff is brand new.
ARP Head studsARP Flywheel boltsOEM RingsOEM Main and rod bearingsOEM Pan, Intake, Exhaust, frt and rear mains, and rear cover gaskets.OEM TensionerPolished crank and camsPower Enterprise Timing belt*planned* ebay exhaust maniS13 SR OEM rebuilt T25N62 MAFSolid Aluminum motor mounts/NISMO transmission mount.SS Clutch lineB&M Short Shifter
Here's where I need help....
I have an auto ECU. From all inidications, it appears that I can use this although my car is a manual. Correct me if I am wrong.
I have checked the FSM and it appears that the power steering pump is attached via some sort of stand-off system with spacers to the block. Is this true? If it is true, could you be so kind as to provide me the lengths so I can mill something on the lathe to use. Or if you have an entra set with bolts that would be hawt. I'm racking my brains out here.
Alternator bracket.... does someone have a spare. I originally planned to weld a piece of flat stock I have to an SR one to create a hybrid, but I am wanting a stock piece so I don't have to crew with it.
Please let me know. Thank you guys.
