Fidel's Project 240 Buildup!
Fidel_Cashflo
Car: 1992 Nissan 240sx S13
SR20det (typical stock swap, some goodies)
Bride seat/Nardi/mint interior
Origin Widebody
Version Select Aero
SSR Type C 19x10.5 +15 all around
I just recently bought a 1992 5 spd hatchback 240, and I got a deal for it, only $1950 and its very clean for having 155k miles. It needs just about everything but the body is very clean, and the interior is decent, everything is mechanically sound. The basic idea is to get the car SR swapped within 3 months while everything else is being done. Im ordering wheels/tires/coilovers within the next 2 weeks. Getting the coilovers installed by a local suspension specialist.
Heres the basic list:Wheels/tires/suspensionTein Super Streets SR20det swap-Z32 MAF-Z32 Fuel Filter-CXRacing Aluminum Radiator-CXRacing Aluminum Shroud-CXRacing twin 12"electric fans-Ebay Stainless 3" downpipe-Ilovetacotaco FMIC + Piping-Greddy Type-RS BOV-Buddy club Spec II exhaustOrigin SpoilerJDM Rainguards Half and Half tail lightsFront lipNew paintPull and roll the fenders
As far as interior:New Shift bootS14 SE seats front and rearUncracked DashOEM Shift knobAlpine Head UnitAlpine 4x6 150w 2 waysJDM Cupholders
Basically a street car, my daily driver that I want to take to autox events and drift days at my local track. Its gotta be pretty reliable and low maintenance once swapped, im not looking for massive boost and ridiculous horsepower, just a little upgrade from the KA.
Modified by Fidel_Cashflo at 11:03 AM 6/6/2009
Modified by Fidel_Cashflo at 1:14 PM 7/5/2009
Modified by Fidel_Cashflo at 9:55 AM 8/22/2009
Modified by Fidel_Cashflo at 10:47 AM 8/28/2009
Encryptshun
Car: 2005 Nissan Xterra
Nice screen name. LOL
You don't need a Z32 MAFS until you put in bigger injectors and need to re-map the ECU -- just go with the stock SR for now. Why a Z32 fuel filter?
Do you not have a driveway, some wrenches and a floor jack/jackstands? If you have those things don't pay a shop to put on your coilovers -- they'll take you about 30 minutes to put on (for all 4) and then about another 2 hours to do ride-height adjustment. Save yourself some cash (unless the suspension guy is doin' it for free).
Also suggest putting in a new fuel pump (Walbro 255).
Get your electric fans out of a Gen 1 Altima rather than buying aftermarket.
Fidel_Cashflo
Origin Widebody
Version Select Aero
Thanks, and the suspension guy is charging $100 per coilover, you honestly think i could do it myself? My good buddy just got Coilovers for his graduation present and his uncle is installing them and he knows what hes doing so I might have him do it just to be safe and it'll be free.
All the things I listed were recomended by a local guy whos done a few SR swaps so I just used that as a basic list to get an price estimate for the whole swap... Right now around $2900 with S13 blacktop including shipping. If I save enough money Ill get some more legit things rather than ebay s***...
Where can I find altima fans?
Fidel_Cashflo
Origin Widebody
Version Select Aero
Started removing rear pieces from the interior and started to pull up the sound deadener.. Everyone complains about it being a pain in the a** but in my case its coming up pretty easy, just using a hammer and a chisel. Im using orange spray cleaner to get up the leftover tar and a brillo pad/steel wool. Im planning on doing a the entire car, just have to find replacement carpet soon.
noobdrftr
Car: of crap...just pure crap
oh man dont use a hammer and chisel to get out the sound deading...use dry ice. I know this because i did hammer and chisel and it took forver.
Osirux
Car: 1992 NA Miata
I wanted to do dry ice. Dont know where the F to buy it.
LingeringSuicide
Car: 1990 240SX hatchback 1993 240sx Vert
look around for some welding gas supply companys in your area. If that wont work try some compressed air cans used for cleaning computers and turn the can upside down, it might be cold enough to harden the stuff making it easy to chip and break away.
TwoJayZee240
Car: 93 RB25 powered hatch
Fidel_Cashflo wrote:Thanks, and the suspension guy is charging $100 per coilover, you honestly think i could do it myself?
If you stripped your interior your self i think you can install a set of coil overs. There is a ton of how-to's on coilover installs on nico.. A easy search and you will be golden!
Fidel_Cashflo
Origin Widebody
Version Select Aero
Alright I'll take a look, I actually havent even looked into it yet lol... If I could do it myself then Ill be saving a good amount of cash.
MastaYu
Car: 92 Nissan 240SX SE HB
Fidel_Cashflo wrote:Thanks, and the suspension guy is charging $100 per coilover, you honestly think i could do it myself? My good buddy just got Coilovers for his graduation present and his uncle is installing them and he knows what hes doing so I might have him do it just to be safe and it'll be free.
Definately do the coilovers yourself
sldewyz
Car: 97' Danger Ranger
yes do the coils yourself. its literally 5 bolts up front and 3 in the rear. front: 3 top of the strut bolts and two bottom knuckle bolts.rear: 2 top of the strut bolts and one bottom of the shock bolt.
Fidel_Cashflo
Origin Widebody
Version Select Aero
Yeah Ive read some how to's im definately doing it myself.. Anyone know a good site to get oem nissan carpet?
Encryptshun
As far as I know there is no place that sells true OEM-fit carpet for the 240. You could try the expensive route and go through Courtesy Nissan, or you could go with one of the companies that sell "fitted" carpets. Google will find you results, or look for Loki's writeup on how to install carpet.
Be advised, though, that even though the place says that the carpet has been pressure-molded to fit your car, it's not to OEM spec, and it's never a perfect fit. You'll need lots of time, patience, and elbow grease to make it really look good.
Fidel_Cashflo
Origin Widebody
Version Select Aero
Damn well im gonna see what my options are for that.
Fidel_Cashflo
Origin Widebody
Version Select Aero
Encryptshun wrote:Nice screen name. LOL
Hey, I just wanna thank you for your help with this... There are some true ***holes on this forum that feel the need to be smartasses in help threads.
Encryptshun
^ and I'm one of them, but what some people need to know is that it's important HOW you ask and how you present yourself. If you come in all c***-and-balls as a n00b, strutting your e-peen but asking really elementary questions, you are gonna get hassled. Not because we don't like n00bs, but because we don't like arrogant, lazy a**-holes who bite the hand that feeds them.
You weren't one of those people, so you got respect.
And regarding your unanswered question about the Alty fans, best bet is local pick-n-pull. You'll need to trim the fan bracket and do some mild wiring, adding in either a toggle or a temperature sensor. But you'll save a hundred bucks or more if you go this route and circulate as much or more air than an aftermarket setup.
Fidel_Cashflo
Origin Widebody
Version Select Aero
The ebay aluminum radiator comes with fans for pretty cheap, I dont remember the exact price but its not very pricey.
RaKoODa
Car: 1995 240sx
keep up the good work.
Fidel_Cashflo
Origin Widebody
Version Select Aero
RaKoODa wrote:keep up the good work.
Thank you.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
keep it up
Fidel_Cashflo
Origin Widebody
Version Select Aero
The KA was running really rough so I took it to our local Nissan specialist and it has a whole mess of problems, but I have to do it... I got quoted $1100 by our family mechanic, and $770 at the nissan specialists. I went ahead and let him do what he felt was needed, i get the car back tomorrow. All hoses were dry rotted, belts have cracks, no reservoir tank, new plugs, wires, caps, water pump, new ac charge, ps leaks, new ps fluid, new fuel filter, oil change/oil filter, the struts and springs are toast he said... So coilovers will be ordered tomorrow, getting strut bars with the order if Megan has em in stock. The build is definately gonna take a little longer due to this bump in the road, Im going to hold off on the swap for a little longer than I initially planned.
Encryptshun
Jesus, man. I don't know about your home situation (ie. if you have a garage, tools, etc), but for what you paid that guy you could have done it all yourself PLUS bought a nice tool set , jack, jackstands and a creeper.
Getting your toe wet in terms of automotive stuff can be intimidating for the uninitiated, but you'll be grateful if you learn to do it yourself. So pick small stuff, do your homework, and start learning your car. It's rewarding, trust me!
Fidel_Cashflo
Origin Widebody
Version Select Aero
The problem is my parents are just skeptical on me working on my engine, they honestly dont care about the rest of the s***, like ive stripped the interior down to almost nothing. Im installing the coilovers myself. Its not a problem of me being able to do it myself but they are just skeptical, they are paying for most of it. I bought everything to this point with my own cash, Ive got $2250 in the bank right now going towards the car.
I work at Outback steakhouse and I make decent money so updates will be coming soon, it will be lowered soon. Its gonna look funny for a few weeks on steelies with hubcaps, but slammed lol
Fidel_Cashflo
Origin Widebody
Version Select Aero
Bought Z 32 rotors/ Z 32 calipers/ 5 lug conversion from a Z32 for $300, and also Im ordering some Powered by max coilovers!
Modified by Fidel_Cashflo at 7:04 PM 6/17/2009
Fidel_Cashflo
Origin Widebody
Version Select Aero
Ended up buying some Teardrop wheels and tires for pretty cheap, and also got Z32 front brakes, sold the rears, and sold all the 5 lug s***. Buying rotors soon for the car.
Fidel_Cashflo
Origin Widebody
Version Select Aero
Dyed the rear seats black, and Im in the process of dyeing the glove box black. All the rear sound deadener is up and is going to be painted with undercoat...
Fidel_Cashflo
Origin Widebody
Version Select Aero
UPDATEI got S14 SE seats, front and rear clean as hell for only $150, the back seats are modded to fit S13... The speakers are gonna be installed when the Alpine Head Unit comes in the mail... Z32 Front brakes on their way, Tein Super Street Coilovers will be here Tuesday. Still saving for brake pads/rotors, since I need 26mm up front, i gotta get the back ones too. The hatch area will be undercoated and and cleaned thoroughly and the seats will be in shortly. Still trying to figure out if I wanna buy the carpet setup, my carpet isnt too bad, and I have Nismo S15 floormats. Im still trying to locate a Chuki lip on craigslist, as you can see I also copped a set of Teardrops, they have brand new tires on em, got em for $240 from my buddy. Sorry pics are bad, my screen broke on my camera so i cant see what im taking lol. A lot of half shots and stuff.
Modified by Fidel_Cashflo at 11:25 AM 7/10/2009
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Hmm, while scanning through this thread I saw the words "Powered" "by" and "max"
I approve!
Asia989
Car: 90 s13.4
jesus where are these 240's coming from
Nismo400R33GTR
Car: 1991 240sx HB s13.5
ya know it's crazy, here in wisconsin it was like impossible to find 240's but i guess all the kids that thought they could, found out they cant, and WHALA inflation of 240's lol, good for us....minus all the bondo were going to have to sand off....ive seen more cars with bondo unsanded lately then i ever have...basic rule of tuning a car if you cant do it right eather learn...or DONT!
