I have two questions: 1. Has anyone had good success using Auto-Rx for HLA lifter tick on the FGY33 models and 2. How to diagnose the annoying rear suspension squeak I have that just started.
I have the infamous lifter tick that has gotten worse over the last month. I use full synthetic 5w30 so I'm sure it's not my oil, most likely minor varnish in the lifter oil passages. I kept hearing about the Auto-Rx treatments for the engine and trans and decided to buy a couple of bottles -- they should be hear by Thursday. I was just wondering, is there anyone who has actually tried it for minor lifter tick and experienced a long term cure? I have tried just about every lifter varnish remover off the shelf (CD1, Valvetech, etc.) and It seems to solve the problem for awhile, but then it comes back. Please let me know your experiences with this supposedly one of a kind treatment.
Second, I just started to get a very annoying squeak in the right rear suspension that I cannot seem to diagnose. Whenever I pull to a stop and then let off the brake to move forward, I hear a dry rubber "squeak" like a tire or rubber bushing rubbing on metal. It also sounds like that when I back up and apply the brakes. I pulled the right wheel off and saturated all the bushings I could see in the suspension with PB Blaster, I pulled back the trunk panel on the right side and sprayed PB Blaster on the top of the strut mount. I can't seem to figure out where it is coming from. I definitely know it is coming from the right rear and can hear it with the windows up or down. Has anyone had this issue on their 97-01 Q and if so, what am I missing? I never had this annoying squeak in the rear and it's starting to piss me off. With the car/tires in gear on the ground I can lay on my back and pull the car slightly forward (with all my might) and replicate the sound, but I cannot discover where it is coming from.
I'd really like to fix this before it gets too cold out. Let me know what to check next!!
Thanks!!
Ted
