FGY33 (1997-2001 Q45) rear shock tower bar installation on a
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
OK I want to update you on my success with the Rear Shock Tower Bar for the G50 Q45.
So far the bar will clear the tank but the bar is and inch too short and either needs to be stretched by a welder. If I can't find anything I will just get a right threaded bolt and weld that to the right threaded part of the stud.
And the bar sticks too far out so either cut it or cut the wall (the plastic wall that protects the tank and covers it as well) its self. As if I were to cut the wall I may just cut up and cover the bar with the broken wall (Which is currently on the car).
But other the two above problems it should work out nicely.
Last edited by Infinitiguy19 on Sat Jan 08, 2011 10:55 pm, edited 1 time in total.
Trumpkin
Car: 1995 G50
Where can I get one? Sign me up!
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
What was necessary to stretch it out? Just the center adjustment bolt?
Sounds like this should be my next mod.
Infinitiguy19
Well to let you all know that it does clear the tank but it will make the back wall stick out a little bit, Unless you cut it which is what i might do.
And yes the center bolt needs to be adjusted to make it fit wide enough because the FSM states there is a 4 MM difference in the shock tower between the G50 and FGY33.
And sadly I might not notice much a difference because i have snow tires on.
I will be glad to announce tomorrow that I am the first person on NICO and maybe the world to have a FGY33 RSTB.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Paul Wall wrote:And sadly I might not notice much a difference because i have snow tires on.
I hear you on that one! I cannot wait to get some real tires back under my car. Unfortunately it's generally not safe to do that until the end of March around here.
Infinitiguy19
We both have traction control, which is better than any tire Mine are Michelin X-Ice I think.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Except that my traction control is disabled thanks to the 4.08.
Infinitiguy19
So its one or the other unless you find a solution to speed up the front wheels.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
MinisterofDOOM wrote:Except that my traction control is disabled thanks to the 4.08.
Why would that make a difference? I thought TCS was measured at each rear wheel or out put shaft?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
maxnix wrote:Why would that make a difference? I thought TCS was measured at each rear wheel or out put shaft?
Since TCS and ABS share sensors, I assumed all 4 wheels were compared for TCS purposes.Honestly, though, I never looked into it too far as the first thing I do after starting the car is hit the TCS off button.
The reasons I came to the conclusion that the diff was the cause are:--"False" codes showing various TCS components being bad when they're known to be good.--Multiple other 4.08 users reporting the same problem (and even the same or very similar TCS error codes that did not exist before the swap).
By my reckoning, TCS would see "slip" constantly due to the rear sensors not matching expected (wheel) RPM at a given speed.
Whatever the cause, TCS fails and shuts off after a random but generally short period of driving, so I removed the fuse to disable it. It annoyed me when it did work anyway. I dislike the Q's crude throttle-modulated traction control and find it to be dangerous at worst and irritating at best. VLSD+TCS is a bad combo, as the VLSD leads to inside slip under power, but TCS puts a stop to that, so you just end up being limited to the traction of the slowest tire.
Infinitiguy19
OK to get this topic back on topic:
OK today I got around to installing the shock tower bar hats, But the adjusting stud is not long enough because it is about 1 inch short, and the shock tower bar sticks out signifantly making it verry hard to install the wall unless you cut it.
And my batteries died in my camera.
But I am going to a place that specialiese in metric bolts, screws and really all things metric to see if they can hook me up with something.
And If anyone is interested in the stud that I will use to install the bar let me know ASAP.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Sorry for the thread-jack.
Paul Wall wrote:And If anyone is interested in the stud that I will use to install the bar let me know ASAP.
Definitely let us know. If that's all it takes to get this working, I'm still interested.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I thought the rear tower brace bar in the FGY33 installed over the tank.
My memory being what it is may not be correct.
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
It sort of wraps diagonally, following the top rearward corner of the tank:
The G50 must have the tank mounted farther forward in relation to the strut towers.
Flagship-Q
Car: 1992 Infiniti Q45
Can't wait to see the finished product. Wonder if Jeff is gonna start making these?!
Infinitiguy19
I am and always will be the father of the rear shock tower bar for the G50.
But here are some pictures for you guys:
More to come.
And yes I know I need some zip ties.
Modified by Paul Wall at 5:02 PM 3/7/2009
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Never have seen the sony mounted up there. Maybe that is where Infiniti mounted the early ones.
Infinitiguy19
Yea but I have some rubber gomets between the metal and plastic mounts for less shock reaching the CD changer.
But the dealer must have drilled the holes to fit the changer.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
They were all dealer installed before 1994.
apossiblehybrid
Car: 1994 Q45
nice i cant wait to see the finished product.
Infinitiguy19
OK just an update.
I have had no luck finding another stud with a bolt with a nut in the middle to adjust it, and I have not had any luck just finding a simple right threaded bolt that is 14 MM by 1.5 MM fine thread. So as you can see this is anything but easy.
I am sure Jeff Willaims encountered problems like this but he found a way.
And another thing I have wondered was to cut the elbows, would it decrease the integrety of the bar?
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
Paul Wall wrote:OK just an update.
Sleeve it. Buy a hollow round bar (maybe 12") with an inside diameter (I.D.) that is slightly larger than the outside diameter (O.D.) of the bar. Cut one side of the strut bar and install the sleeve over the cut-secure it at the right distance and then have it welded.
Infinitiguy19
Way ahead of you, I found the bolt that I needed in my spare bolts from my 1991 Q45 part out. The bolts is a heat treated 14x1.5MM fine thread from the differential.
So for those of you with part cars you are about to have people asking you for these bolts.
So I cut the bolt and I am going to butt weld it to the other stud that came with the bar and weld a sleeve over it for added strength.
Pictures tommorow.
All that is really left to do is cut the wall or put it and see how it looks.
apossiblehybrid
Car: 1994 Q45
Paul Wall wrote:Way ahead of you, I found the bolt that I needed in my spare bolts from my 1991 Q45 part out. The bolts is a heat treated 14x1.5MM fine thread from the differential.
Pictures tommorow.
sounds good. i cant wait to see the pictures!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Nice! Keep up the great work Paul. I really appreciate the pics; thanks for sharing. I hope it works out for you exactly the way you want it.
Infinitiguy19
Thanks, I have come to a cross road.
1. Keep the bar the same and cut the plastic trunk wall and lose trunk space.
2. Cut the bar and lose only a 1/2 inch max and have a straight bar, but have a machine shop do that work.
Either way progress has beeen haulted because I need to do some work on my car to get it running right (nice and quiet).
Infinitiguy19
Just a question for Q45tech before I proceed by custom making one $30,
Does the current (thin metal on the lowest part of the shock towers) Rear shock tower bar in the G50 make any difference in the rear?
I have been told by some that it is a good bar, But despite all the strength too it I think its too low on the towers to make any effect, What are you thoughts?
And after reading your posts you say that tires are 80% of the grip/feel of the car the rest is in the suspension set up. so would this yeild the same effect as the FSTB or the Q45a rear sway bar?
Modified by Paul Wall at 5:51 PM 3/16/2009
Last edited by Infinitiguy19 on Fri May 07, 2010 11:15 pm, edited 1 time in total.
goody90q45
Car: 1992 Infiniti Q45 (sold)
Does the 97+ Q45 come stock with a RSTB? If so wouldn't that be a better candidate for this mod rather than the shorter Maxima bar?
Once you weld on a hardened part it loses its tensile strength. Is the butt weld in the center of the bar going to hold up to the lateral forces the first time you drive over a speed bump a little fast? Unless I'm not seeing the big picture I think the weld may snap the first time it sees a hard jolt.
If you're going to use a machine shop, ask if they can make you up an opposite threaded bolt on a lathe and get it hardened. Probably a bit more cost but better to start with the correct part.
How much clearance between the bar and the gas tank? Can you show a close up of the bar attached to the bracket? Looks like a fun project and you're paving the way for future NICOnauts.
bullittandy
I can't really tell where you're at with this but wanted to clarify what problem you're solving-making it fit, or making it fit within confines of trunk carpeting.
I don't think you need to mess with the bolts and jam nuts and the like, all you need is for one side to be a bit longer and the easiest way to do that is to cut one side of the bar and put a sleeve over the cut. Or am i missing something?
Q45tech
