goody90q45 wrote:Does the 97+ Q45 come stock with a RSTB? If so wouldn't that be a better candidate for this mod rather than the shorter Maxima bar?
The 1997 Q45 came with a RSTB and whats what I got from Andy to start this project, Its whats this project is based on. I am not sure if the Maxima came with a RSTB but I remember hearing that Jeff Williams had to cut them down.
goody90q45 wrote:Once you weld on a hardened part it loses its tensile strength. Is the butt weld in the center of the bar going to hold up to the lateral forces the first time you drive over a speed bump a little fast? Unless I'm not seeing the big picture I think the weld may snap the first time it sees a hard jolt.
I THINK I came up with a way to fix that and it doesn't involve a butt weld like I previously wanted to go with.
goody90q45 wrote:If you're going to use a machine shop, ask if they can make you up an opposite threaded bolt on a lathe and get it hardened. Probably a bit more cost but better to start with the correct part.
How much clearance between the bar and the gas tank? Can you show a close up of the bar attached to the bracket? Looks like a fun project and you're paving the way for future NICOnauts.
I asked a place in an industrial park I frequently pass by and the guy said ~$100 when its all set and done for the parts shown bellow:
http://picasaweb.google.com/lh...tlink
There is plenty of clearance for a straight bar to go across the tank. But my main concern is that if the metal snaps then there goes the tank. So thats my FIRST priority.
Like I said the shop wants ~$100 for 2 solid bars one with right and another with left threads. Of course 2 holes for 10 MM studs to fit though for the Rear Shock Tower hats.
Well we have you Mike with the rare cup holder (No joke), Wes with the NICO ECU's, Jeff with the FSTB and me with the RSTB, But thanks Mike.
But for now I am looking for a shop with a fair price (no more than $30). But I need to know who is defiantly interested? I mean seriously interested!!! (Can't stress that). I also will do this for the price the shop charges plus $5 for some pocket change for me to fund my future projects.
And to all who wish to know: Nearly all my current projects would be done if I had the parts (money) to finish them. But I have all the plans that are needed to make them a reality.
Also you will need:
The bar (What ever the final cost)
The FGY33 rear shock tower hats: RH: 554A6-6P000- LH: 554A7-6P000- Both $12.04 from Infiniti Of Scottsdale (or you can buy used).
The nuts: 4X: 08918-1081A- ($0.60 each) 4X: 01225-00102- ($0.82 each) ( 8 all together and they are really 10MM nuts same as the ECU/TCU kick panel cover).
And of course the center stud to adjust the RSTB only found on a FGY33 (1997-2001 Q45).
Modified by Paul Wall at 7:58 PM 12/21/2009
