goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Fri Feb 18, 2011 6:32 am
With only one or two exceptions I don't recall anyone having trouble down the road when installing new injectors, whether OEM or aftermarket. It's probably going to take at least 10 years before we hear about failures. It's a bit of a crapshoot when using using injectors, even the "refurbished" ones from the few reputable injector shops we've found.
I live in CA and haven't had any FI problems on my 90Q for over 2 years and only replaced 2 on my 94Q in 4 years of ownership. Both cars were the previous owner's daily drivers. I had to replace 6 injectors on the other 90Q I bought and sold. It had sat unused for over 9 months. I've also parted out 3 other Q's that were running when purchased and from the 24 FI from those cars I was able to recondition (through Deatschwerks) and sell about 2/3. The ones I held back were too brittle, had cracked connectors, some failed ohm test.
With that said, IMHO, the main cause of injector failure is cars that sit idle for months at a time with stagnant fuel eating away at the epoxy holding it together. Ditto with injector rails purchased from salvage yards. Many owners that join NICO come in inheriting injector issues from cars that the previous owner had sitting in their driveways for a long time. The buyer has no idea how long it's been since the car was running. A second contributor to injector failure is dirty/corroded connectors. High resistance in the circuit to any of the injectors can't be good and will lead to an early demise. Ditto for problems many members have with MAF sensors. I've had MAFs (and TPS and CAS) from 7 CA Q's and never had a bad one. If you live in a bad weather state or have ever had a radiator leak you probably have some level of corrosion on the FI, MAF, TPS and CAS connectors, none of which are watertight. A third contributor to FI failure is varnish deposits in the fuel system. Every Q, no matter how much or how often it's driven will have some level of deposits. I use a bottle of Redline S1 fuel system cleaner in a half tank of fuel about every 6 months to keep the FI from gumming up. My 2 cents.
