Yep, Nissan would prefer us to all get in line for a new Infiniti and get rid of our overengineered warriors.Q451990 wrote:I'm trying to reach Joe to see if Nissan is addressing the issue, but my guess is that they would be happier to see our 12-18 year old cars die than to source a newly manufactured injector.
So... what do you guys think?
Heath
I thought the NICO moderators got a large monthly stipend to buy these kinds of things?elwesso wrote:thats interesting.. I guess someone is gonna have to pony up and see how they work.
I think so... one person at O'Reilly mentioned a lifetime warranty, but their web site doesn't reflect that.elwesso wrote:Do they have a regular 12/12 warranty?
I would love to see their testing. The aftermarket ones come in three different styles that correspond to the color dots on the OEM injectors, so I suspect they have made an attempt to flow match them at the factory as well.goody94q45 wrote:It would be nice to send it in to DeatschWerks for flow testing and comparison to OEM. Dave Deatsch is a member so an email might get a response in this thread.
Wes emailed me about this thread and asked me to make a post. Wish I had the time to get on here more often. Anyways, I'd be willing to test a set of these new aftermarket injectors if somebody buys them. I would like to test not only flowrates but also coil response and spray pattern. My experience with "OEM equivalent" injectors is that they are not equivalent to OEM. But I'm not afraid to be proven wrong.goody94q45 wrote:It would be nice to send it in to DeatschWerks for flow testing and comparison to OEM. Dave Deatsch is a member so an email might get a response in this thread.
Q451990 wrote:Thanks Wes!
Just tossing something out there about the flow matching on the injectors with the different color dots. My thought has always been that it is just too difficult or expensive to manufacture injectors with exactly the same flow pattern - so they test them at the factory and divide them up into three groups depending on their spray pattern and maybe some other characteristics. Each group gets it's own color code, and they make sure that they install all 8 injectors with the same color code on any given engine?
In other words, the color code is just for matching the injectors with each other... not for tuning the injectors to an individual engine. Is that everyone's understanding of it?
If my theory holds, then if you're replacing a full set of injectors, or even a full rail (since the ECU adjusts each bank of injectors a batch for pulse width based on feedback from the O2 sensor) then you should be fine.
Heath
Modified by Q451990 at 12:20 PM 6/26/2008
So you have used the BWD injectors? How did they hold up?Q45denver wrote:Possibly, but would not explain different color dot specification by year. I think you would still want to use the same spray pattern on each bank. The only time I had a problem with different color injectors was when I put some different color BWD injectors on one side and some OEM on the other side without first testing them.
Well, that's the thing... my understanding is that the Standard Motor Products facility in Greenville produces the injectors, but doesn't sell them - at least at retail. They are contracted to make them for BWD and Niehoff and they are sold at places like O'Reilly and Advance Auto. I can check with the local stores, but I have some serious doubts about them agreeing with my sending a set of 8 off for independent testing with the caveat that I can return them if they don't meet OEM performance. My guess is that their warranty only covers replacement if they don't work.elwesso wrote:Heath, it sounds like you're in there with the parts guys, you want to see if they'd let you buy one and then return it after we let david mess around with it?
I'm not sure who made them but they came in a BWD box from NAPA I think. I could not get the car to run right with them so I returned them and installed OEM. Would be interested to know who else makes aftermarket injectors as the ones I've seen all had either the Nissan or JECS stamp.Q451990 wrote:
Heath
I think BWD is owned by Standard Motors. I returned the injectors I bought from NAPA directly to BWD and they refunded my purchase price which was pretty nice. Why don't you call BWD, maybe they will send you a test set.Q451990 wrote:
I'll see what I can do... and thank you David for your generous offer to test them!
Heath
Do you remember when you purchased yours? The BWD person that I talked to said that they were made in China prior to sometime in 2007. Then they changed production to the Standard plant in Greenville, SC last year.Q45denver wrote:I'm not sure who made them but they came in a BWD box from NAPA I think. I could not get the car to run right with them so I returned them and installed OEM. Would be interested to know who else makes aftermarket injectors as the ones I've seen all had either the Nissan or JECS stamp.
This was a couple of years ago. They were phase ones with the Nissan seal. Perhaps they were factory seconds that BWD repackaged?Q451990 wrote:
Heath
That is understandable that they wouldn't take it back.Q451990 wrote:Alright... I checked at my local Advance Auto store today, and they're "between managers" - but the crabby old guy that had been there the longest said they wouldn't take them back after they have been tested. He said they're not guaranteed to perform as OEM, since they're aftermarket.
