Ok my brother has a92 240sx 5spd which is all stock except CAI the problems are as follows
1. the car seems to have flat spots and bogging in power when pressing the pedal anywhere from 20%-100% (happens ALL the time)
2. some times the car will buck extremely bad when starting from a stop usually gets worse when you give it more gas but if you SLOWLY leave a stop it acts normal.
3. when the car is taken up to high rpms after bogging out before it can get to redline the car will stall when the clutch is pushed in, but after 5 or so minutes on very light driving or downhill coasting with clutch out it is fine again.
4. When the car is shut off it takes a couple seconds to actually shut off.
Im thinking one problem is the temp sending unit connector was cut off and "rigged" together with spade terminals. I also think all the problems are connected.
thanksGary
