hayaimoto »
https://forums.nicoclub.com/hayaimoto-u51882.html
Tue May 08, 2007 8:04 pm
Do a compression test and a leak down to make sure the motor is still healthy, never know what KA's will do on boost, the turbo might be fine but if the motor is going to go out, that may be a problem. If there were a boost leak your gauge would show peak then a drop off (decline of boost) atleast. Another possibility is the transmission is slipping hard during more boost becuase common sense is that more boost = more power. Good luck man
