feels like im towing a Honda
S13FX
Car: '69 l20b Dimeski :)
yes, my friend if you have a huge exhaust leak at the flange to the turbo, it's not a good thing, that means you are loosing the exhaust thats suppose to be spooling the turbo heh.
GEO
Car: 95 240sx KA-T
i run an auto with 8psi fine.. i ran it before with 10psi.. fine.
VeloceDrift
Car: 1993 Nissan 240SX S13 coupe
1995 Nissan KA24DET
GEO wrote:i run an auto with 8psi fine.. i ran it before with 10psi.. fine.
lol im really glad you said that cuz i have been worried about the transmission even though it seems fine
esahuque
Car: 95 240sx KA-T, 04 frontier
Ive read alot about auto trannys on boost. a lot of people would say keep the auto transmission and put a good cooler on it. it sifts faster then any person can, plus you never miss a gear. the auto transmission can handle the HP. wish i would have keep mine, I did a 5 speed swap. to late now
VeloceDrift
1995 Nissan KA24DET
lol lets trade cars then;) i am just tired of the auto.. i miss my old 5 speed and cant wait to get one in my car. although it is a pretty amazing feeling when your auto shifts under boost and you fly ahead of your opponent.
myRed240
Car: '95 Nissan 240SX with a KA-T!
'07 Audi A3 2.0T DSG
'11 G37S Sedan
How is it holding up? Are you running a different trans cooler? Also, has your O/D light ever flashed repeatedly upon start up?
Thanks!
So far I'm really liking the auto trans + turbo combination. I've noticed it slipping after repeated highway runs, but I just need to change the fluid to a heavier weight.
VeloceDrift
1995 Nissan KA24DET
My OD light used to flash repeatedly.. then i accidentally broke it off one day:-/
VeloceDrift
1995 Nissan KA24DET
question for ya:
So i just got my flange re-welded and we made sure it will not happen again. When i took my car for its first test run it boost like a maniac and was hauling ***. after it warmed up it went back to the same old thing. The more i boost the slower i accelerate. I have a feeling that it is my transmission:( one thing i noticed was that when i used to turn my overdrive off when i let off the gas my RPMs would fall to about idel. now when i turn over drive off it does not drop RPMs at all when i let of the gas.. can this be a sign that its my transmission?????
S13FX
Well the problem with Automatic trannies is that they are very very picky about the fluid temps, and capacity since it works off of valve body and amount of pressure applied.
So if you think about it, when you drive hard all that stuff heats up especialy under boost, when that happens we all know your fluids loose their property. This might not necessarily be your transmission going bad just your transmission fluid heating up and not working like it's suppose to.
But then again if your transmission fluid isn't doing what it's suppose to it might also be doing damage to the transmission cause it's not doing it's job.
Usually turbo automatic cars have some type of a transmission fluid cooler installed.
VeloceDrift
1995 Nissan KA24DET
S13FX wrote:Well the problem with Automatic trannies is that they are very very picky about the fluid temps, and capacity since it works off of valve body and amount of pressure applied.
good call.. yeah i will have to check into that. The wierd thing is that it ran fine on 8psi for about two weeks before it started doing this but i know for a fact it is heat because it just started to reach the mid 80's here which is the highest it has been since my car has been turboed. i drove to work dismorning when it was cool outside and it was fast as hell but one i got off the freeway and everything was warmed up it was doing it again. thank for the advice. i hope this is what it is so i can start laying the smack down on fools.. lol
SOHCSE
Car: 1990 240sx SE
VeloceDrift wrote:lol lets trade cars then;) i am just tired of the auto.. i miss my old 5 speed and cant wait to get one in my car. although it is a pretty amazing feeling when your auto shifts under boost and you fly ahead of your opponent.
Keep the auto, run a good trans fluid cooler, get a transmission controller, get a Shrifter.
Paddle shifting FTW!
VeloceDrift
1995 Nissan KA24DET
you think??? i am really afraid of it blowing up. well i will hold on to it until that day whenever that is.. lol hopefully not soon. Whats a good transmission cooler to run? and whats a transmission controller?? im not knew to the whole car thing just new to the whole automatic thing.
SOHCSE
Car: 1990 240sx SE
VeloceDrift wrote:you think??? i am really afraid of it blowing up. well i will hold on to it until that day whenever that is.. lol hopefully not soon. Whats a good transmission cooler to run? and whats a transmission controller?? im not knew to the whole car thing just new to the whole automatic thing.
Check theese out: Turbocharging your Auto 240sx
Paddle Shifted 240sx
Im going with a TC and the Shrifter. Do a search on transmission cooler. There is a great article written on the matter. I think it was the same person that did the 'Paddle Shifted 240sx'. Should be easy to find. good read!
VeloceDrift
1995 Nissan KA24DET
So i just checked the trouble code that my ECU is spittin out. Its throwing out code 34 which is the Detonation sensor circuit.. i here that is cause by a bad knock sensor.. whats a knock sensor and is that the only thing that could cause code 34??? maybe this my problem???
VeloceDrift
1995 Nissan KA24DET
dudes???
VeloceDrift
1995 Nissan KA24DET
turns out it was the knock sensor the whole time.. . pretty damn easy to change if you ask me.. everyone is making a big hype about it but it was easier then changing my oil. all i used was a 1 foot extension, 12mm socket and a grabby claw thing....
