Running like straight A$$!!! No power under load, high idle, spitting and sputtering
Pulling ZERO codes (55)
I have ECUTALK so TPS is set to .40 with throttle showing closed. and timing set to 15 degrees.
New plugs(correct NGK ones) gapped .040
5of6 injectors ohm'd 12.3, cyl #1 bounced all over! Well i had an extra injector that shot good so now all injectors are good!
All injector wiring ohms good to the ecu
All coils ohm 1.1 and have good continuity to the PTU.
Ohm'd the PTU as per the 94 FSM, good! .504ohms
Reviewed both these links
ptu-subharness-delete-t563983.html
running-out-of-ideas-t564182.html
I don't want to spend 167 via Concept Z for one but if that is going to fix it.
On a good note the AC blows nice and cold
Thinking PTU or CPS
So the big QUESTION is
