Ok so it's not your injectors, pcv valves, CAS, TPS, and probably not your PTU. That leaves... MAF, IAA valve, vacuum leak, the throttle cable itself, dirty/binding throttle bodies, etc.
You can try doing this and see if it helps:
http://s95014253.onlinehome.us/63104/15 ... on*id*val*
Also pull the plastic intake pipes and make sure your throttle bodies are opening correctly when the pedal is depressed, and make sure the cable itself is tight and adjusted correctly.
A vacuum leak, even a small one, can cause rough idle and lack of power.
