few years racing already so I'm not scared to give him some power. He gets the whole Spiderman "great power thing".
I'd whoop his @$$ if he goes Japanese on me and drifts all over town.
Somewhat limited budget so keep that in mind.
I'm good with the bodywork, paint, most of suspension, electrical, 4pt harness/roll-bar safety, and most
other things. Just the turbo part of the build has me a little lost. I've built plenty of engines but all N/A.
I have read so many posts and stickys on here that I'm starting to get mixed info. You know, that
point when you think you have it figured out but then someone else says something contradictory? lol
So here is what we are planning based on what we have researched. WDRacing has be very helpful, so thanks!
Rebuilding the KA24E engine with new bearings, pins, gaskets and such, but not changing any major parts except new cast pistons.
Tial F38 Wastegate (was free)
CXRacing 31"x11"x3" 3" Inlet & Outlet Intercooler and Piping
Godspeed Turbo T04E .50 A/R Comp, .63A/R Turbine (Running 6-8psi to start)
Turbo Insulation/Heat Shield if needed
Godspeed Cast Turbo Manifold Top Mount
LC1 Wideband 02 Sensor and Gauge
Walbro 255lph
OBX 8:1 FMU
NGK BKR7ES-11 Spark Plugs
Stage 2 - (Maybe 3-4 months later)
Nistune 1 board and software license
550cc Top Feed Injectors, Stock Rail
XTD Stage 3 Clutch Kit (might do this when rebuilding engine)
MAF Z32
Bump Turbo to 10-12psi
So I have a few questions I would really appreciate your help on.
1. Do I need an adjustable Fuel Pressure Regulator? And if I do, I presume I don't need it until stage 2 correct?
Is there a brand that is affordable and reliable? I don't need cheap, just affordable. Seems like everyone
recommends the Walbro 255lph for fuel pump so something along those lines of cost/reliability for the regulator.
2. 550cc Injectors. I've read that RX7 89-92 Injectors are a drop in match. Is there a model number I should
be looking for or something? Denso R-093? There seems to be so many different options. Kinda lost here on this!
We can't spend more than $200 for these. 550cc should be enough for this setup right?
3. BOV. Is there a certain brand here that isn't $120+ that we can get away with? Seems crazy that they have
some for $26 on eBay and then the TiAL QR 50mm is $275! I'd like to be around the $60-80 range if anyone
can suggest one. I think my son wants to do Atmospheric instead of Recirculating setup if that makes a
difference. I know there is some extra work and a trick to it, but he's 15yrs old. He wants to sound all loud
and crap too. haha
4. Downpipe. Is there a downpipe that we can get that will fit the Godspeed Cast Turbo Manifold without having
to be all custom? Don't have ABS or A/C if that matters. Maybe I should just call Godspeed directly for their advice?
5. 3" exhaust all the way? Not doing any CAT or anything emissions on the car since we don't have to worry about that here.
6. What do I use for boost control? Is there a standard brand/setup that everyone uses? I'm not talking like a MSD box
or anything like that, just some type of PSI knob. Any suggestions?
7. What about a rev limiter? My son suggested a Bee-R Rev Limiter but I think he just wants some flame shooting action.
Either way is this a good idea to keep this engine from exploding on him? I wouldn't worry about it if he was in his road
course car, but a drift car is a little different I would imagine. If needed, can I wait until Stage 2 for this $300 purchase?
8. Since we'll be getting rid of the OBX when we get the Nistune, can we run stock injectors and be ok with 8:1 for now
or should we get 6:1? Or should we get the 550cc in Stage 1? Seems like I read that getting 550cc would be stupid unless
getting the ECU tuned alone with it. Just want to make sure on both of these questions here.
For now that is all I can think of.I don't want to waste money on anything stupid here, but I hope you can see I don't
mind spending a little bit on my son. I just have my own car projects that also take some serious cash! ('52 Split Window VW Bug)
I really really appreciate any help I can get here! Thanks for letting me lurk the past 2 months!
Fetam
(From the land of polygamy)
