Injector Spread Sheet
WDRacing
Here's my list of Injectors:
Top Feed Engine Style Size Impedance* Years / ModelsNissan KA24E Top feed 260cc High S13Nissan CA18DET Top feed 370cc Low S13Nissan RB20DET Top feed 270cc High R32Nissan RB26DETT Top feed 440cc Low R32/R33/R34 Mazda FC NA Top feed 460cc Low 86-87Mazda FC NA Top feed 460cc High 88Mazda FC NA Top feed 460cc High 89-91Mazda FC turbo Top feed 550cc Low 86-87Mazda FC turbo Top feed 550cc High 88Mazda FC turbo Top feed 550cc High 89-91Mazda FC NA Top feed 680cc Low 84-85 DSM 3000GT/Stealth turbo Top feed 360cc Low 91+DSM Talon/Eclipse nonturbo Top feed 390cc Low 89-94DSM Talon/Eclipse 1G Top feed 450cc Low 89-94DSM Talon/Eclipse 2G Top feed 450cc Low 95-99Mitsubishi Evo Top feed 510cc Low Evo 1-Evo 3Mitsubishi Evo Top feed 560cc Low Evo 4+
Subaru WRX Top feed 420cc 02+Subaru JDM STi Top feed 525cc 99+?? Toyota 3S-GE Top feed 295cc High Toyota 7M-GE Top feed 295cc High Cressida, Supra mk3 NAToyota 2JZ-GE Top feed 315cc High Supra mk4 NA, SC/GS/IS300Toyota 3S-GE Top feed 315cc High Toyota 7M-GE Top feed 315cc High Cressida, Supra mk3 NA
Side Feed Engine Style Size Impedance* Years / ModelsNissan KA24DE Side feed 270cc High S13/S14Nissan SR20DET Side feed 370cc High S13/S14Nissan SR20DET Side feed 480cc High S15Nissan RB25DET Side feed 370cc High R33/R34Nissan VG30DETT Side feed 370cc High Z32
Infiniti VH45DE Side feed 370cc High All Years
NOTE: 90 - 94 Z32 uses a style of injector that is non-compatable with KA fuel rails (still sidefeed), while 95 - 96 uses the same injector as the RB25DET and SR20DET, etc.
Mazda FD Side feed 550cc High 93-98Mazda FD Side feed 850cc High 93-98Mazda 20B Side feed 550cc High JDM Mazda Cosmo?
Subaru JDM STi Side feed 550cc (565cc?) High pre 99Subaru STi Side feed 565cc High 03+ Toyota 7M-GTE Side feed 430cc (440cc?) Low Supra mk3 turboToyota 2JZ-GTE Side feed 550cc Low Supra mk4 turboToyota 3S-GTE Side feed 430cc (440cc?) Low MR2, 91+Toyota 4A-GZE Side feed? 365cc Low MR2, MK1Toyota Celica GTS Side feed? 310cc High 2000+Toyota JDM 1JZ-GTE Side feed 430cc Low Chaser, Supra mk3?Toyota JDM 2JZ-GTE Side feed 430cc High?* Supra mk4 turboToyota JDM 7M-GTE Side feed 430cc Low Supra mk3 turbo
Ford Turbo Coupe ?? 30lb (~315cc) Low 86-89Ford Turbo Coupe ?? 35lb (~365cc) Low ??Honda Prelude (H22A) ?? 345cc Low 92-96 VTEC
*ImpedenceSaturated = High ImpedencePeak and Hold = Low Impedence
Thanks to IWannaS15 for sending me the original list!!!
If you have additional info, please feel free to post it, I'll then add it to the database and delete your post. This is to be kept clean at all times, anything other then injector info will be deleted post haste...Thanks
nissanfanatic
Car: 1992 Nissan 240sx SE
The following chart displays the maximum obtainable CRANKSHAFT horsepower vs. injector flow rate at 100% duty cycle, assuming a BSFC of .55 lbs./hp/hr. For Wankel and 2 stroke engines, multiply max hp in table by 0.9 to compensate for the higher BSFC of these engines. Injectors should be sized for 75-85% maximum duty cycle on engines used in constant high power applications such as race cars, aircraft and boats.
Just HP vs flow. From http://www.sdsefi.com
TeckniX
I believe :Toyota Celica GT (5sfe engine) has similar 315cc high impedance injectors as the Toyota 3s-ge - might be easier to find :P
96240SX41
Car: 1996 240SX
TeckniX wrote:I believe :Toyota Celica GT (5sfe engine) has similar 315cc high impedance injectors as the Toyota 3s-ge - might be easier to find :P
I second that one!
Nismo_Freak
Car: 89 Nissan 240SX
SR20VE / SR16VE - 333cc Grey Top Injectors
KATwo40
Car: 1993 240sx KA-T
Pretty sure the Toyota MR2 3sgte uses top feeds.
Great reference guys - Good work!
And welcome to our visitors from elsewhere - this page has been pretty popular!
WDRacing
2 best lookin mods on nico....what did ya expext...lol.
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
nissanfanatic wrote:The following chart displays the maximum obtainable CRANKSHAFT horsepower vs. injector flow rate at 100% duty cycle
According to that chart a set of 615cc should max at ~ 429 crank hp...??? Then that would mean ~ 356 whp...
Why does that not sound right..??
WDRacing
A general rule I use, take the number of cc's subtract 100 and thats the WHP you'll net.
rn240sx
09 Ninja 650R
06 Suzuki S40
S
WDRacing wrote:A general rule I use, take the number of cc's subtract 100 and thats the WHP you'll net.
so 615cc - 100 = 515 whp..??
Still sounds off to me. All other calculations state ~400-425 whp. Im not doubting u in any way but 515 sounds a bit high but would be SWEET if that was the case..
Iamjohnhayes
Car: 89 Single Cam Hatch
well doesn't it also depend on the num ber of cylynders my friend with his turbo mustnag only uses 24lb injectors which are smaller than stock ka injectors how ever he has twice as many of them so they therefore provide enough fuel.
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
hannibal
Car: Red Line to Glenmont
Someone on ka-t.org posted a link to a OEM injector reference guide. They are listed by part numbers and has a picture of each, plus flow rate and impedence.
http://www.witchhunter.com/injectordata1.htm
fogleroller
no, side feed
Zenki-des
Car: s14
do the vh45 injectors drop right in the ka24de fuel rail?
WDRacing
Yes
PencilShavings
Car: '91 240 hatch
do mazda FD sidefeeds fit the stock fuel rail? do the electic plugs fit also?
are 550s from the twin turbo?
WDRacing
Mazda FD Side feed 550cc High 93-98 are the injectors you'll want. Yes they drop into the rail but I don't think the clips match up. I haven't used any so I can't say for certain, I switched to top feed right off.
WD
ZiG
Car: 1993 240sx coupe
Ok, here's one for ya. How much work would be involved in making standard ford/gm style delphi injectors fit a KADE intake manifold?
Edub1
Car: 89 240sx KA-T
Are the injectors in that list ones that fit the KA engines?
hannibal
No, theyre injectors that MIGHT fit based on top/side feed or hi/lo impedence. Some of them drop in, some need clips or O rings...
ZiG
WDRacing
To make ANY of the top mount injectors fit a KA24DE you'll need a new top mount fuel rail. Project Silvia sells them for like $30. http://www.projectnissan.com/s...=3701
northstar ninja
Car: 74 260Z, 92 240sx hatch.
nice.... tha
WDRacing wrote:To make ANY of the top mount injectors fit a KA24DE you'll need a new top mount fuel rail. Project Silvia sells them for like $30. http://www.projectnissan.com/s...=3701
nice that way i can switch to dsm 1g injectors my friend has laying around... all i need to do is wire in resistors.....
nismo_power
Car: 91 240sx fastback se
hey so will the j30 injectors work for the kade rail...is it a plug and play job???
WDRacing
I think they are drop in replacements, but there may be a year or two that doesn't match. I just can't remember...
nismo_power
are these 370cc also???
WDRacing
Yes
nismo_power
here is my problem i got the injectors but they are still in the rails and i cant seem to get them out of the rail...what is the easiest way of getting them out without damages them???i damaged one already and i dont want to risk the rest...i got 5 left to try to get out without damaging them...thanks for all the help...
