Fastest powered KA in the US?
TropicalJewel
Car: 1995 240sx se
Here is da link...
http://www.racingsouthwest.com...e.wmv :bowdownSmokin... So whatcha think??
Monique
gumby
Car: '89 240sx sohc
i just wanna drive to work
Exar-Kun
Car: 2005 350Z
bad. freaking. ***.
very nice, very nice.-chet
NX95240
Car: my KA-(sc61)
damn that quick !! any more vid. of that car?
240sxHitman
Car: Boosted '91 240sx
as a fellow f/b driver im glad to see that hope to be up there one day
sxseguy
Car: Makin' it go faster!
BTW, that's all motor with a shot of nitrous.
GEO
Car: 95 240sx KA-T
yep.. NCIE! MODS?
IlIkEmYz
Car: 06 Z
TropicalJewel what did you do to your car, engine/ weight reduction, etc???
keepingthe240
The fastest ka24 on this board ran 9's. He was selling it on this board a few yrs ago. He wanted $20k for the rolling chassis. But i assume your talking about the fastest street driven
sxseguy
Was that 9 seconds on ALL MOTOR? If not then it was the fastest KA24DE-T, while this is the fastest KA24DE. There's a little more to the story here.
The car is not TropicalJewel's, nor is it mine. I've never even met the guy, while TropicalJewel has. I know it's a blazing fast non-turbo S13, though.
TropicalJewel
Car: 1995 240sx se
Ya I have met him, but that in no way is my car. I just wanted to share his success with ppl. See the responses. KA no turbo, just nos. Bout all I know as well. That is all i saw the last time i saw him race. NOSSSSS!
Mo-
keepingthe240
With those #'s , i figure it was turboed. Hi compression loves nitrous. I assume it's not daily driven then. I'm not really impressed.
w1ngzer0
Car: Pfft. i don't own a box
im impressed with any 4cyl that runs under 12's. Essp being being all motor :D
Thats great man. You have ITB's?
got_boost702
Car: racing, cars, snowboarding
Nitrous is not all motor. Nitrous is forced induction.
Unless he wasnt spraying on that run because is says in the forum he leaves it in 11s for bracket racing and puts it in 9 second trim for import events. So i assume nitrous is used to run 9s but thats a big jump from 11s to 9s. Still a sick car, no matter how you look at it.
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
That brings a tear to my eye. Damn i need a better job.
Exar-Kun
Car: 2005 350Z
"Nitrous is not all motor. Nitrous is forced induction."
thank you.-chet
Ecnorcs1
Car: Cars & Fishing
That was bad ***, I wanna see some specs.
keepingthe240
Lets try 15-1 compression with alky. <--all motor But not the sad note..hondas are running 9's all motor and a neon ran 11's all motor
Doomed2Walk
Car: 2005 Subaru Impreza WRX STi WRBP on gold
Nitrous isn't really "forced" induction I thought.
Exar-Kun
Car: 2005 350Z
anything shoving more oxygen into the combustion chamber than would have been there through normal engine duty/atmosphere is forced induction.-chet
s14a
Car: 98 240 white
^^amen to that
Nismo_Freak
Car: 89 Nissan 240SX
Exar-Kun wrote:anything shoving more oxygen into the combustion chamber than would have been there through normal engine duty/atmosphere is forced induction.-chet
It's not shoving more air into the engine... the engine is still naturally inducted because there is no positive manifold pressure.
Nitrous is a power adder, not forced induction.
Exar-Kun
Car: 2005 350Z
nitrous has a higher oxygen content than atmospheric air, and its being forced into the engines intake tract..thusly, its a form of forced induction.-chet
ShadowKnight006
Car: 95 240SX & 96 Altima
I was about to say someone needs to find that guy and get him on NICO, but not after reading the rest of the thread and seeing the pis***g contest it turned into between drifter and draggers after that guy said drifting sucks.
Projex240
Car: Dogs , My RIDE
NITROUS IS NOT FORCED INDUCTION.
Forced induction is where compressed air causes pressure above an atmospheric rate in the intake manifold. The nitrous is ingested naturally through an intake tract. BY saying its forced induction, you also say that alky injection is forced induction as well. I suppose ram air is forced induction? no--power adder--yes. forced induction, absolutely not. Oxygen content Desnt have anything to do with how nitrous or any other foreign prporty is introduced into an intake tract, nitrous is breathed in just as the air around the filter. if you open a bottle of nitrous above a filter element, and rev the motor--what happens? does the nitrous get forced in? nope--it gets sucked in. forced induction---higher induction rates as a result of boosted atmospheric condition(above 14.7) in the intake manifold. Next time you see someone spray --if they have a turbo and a boost gauge--check their boost gauge--youll rarely see an increase, and if you do--is because of the efficiency increase cuased by lower temps that occured when they sprayed.
-josh
whiterps13
Car: white LE hatch
Exar-Kun wrote:nitrous has a higher oxygen content than atmospheric air, and its being forced into the engines intake tract..thusly, its a form of forced induction.-chet
i totally agree, if you are talking about a dry system. imo a wet system is a power adder, not forced induction. dry and direct port use force to enter the engine, while wet systems just add nitrous to the gasoline.
Exar-Kun
Car: 2005 350Z
" suppose ram air is forced induction?"
no its not, it's not shoving more oxygen than is natural, or presurizing air into the intake tract. this isnt hard to figure out. and by typing in caps, it doesnt make you right. alchohol injection or meth engines are a completely different ball gamelets keep this to gasoline powered engines, shall we?
"if you open a bottle of nitrous above a filter element, and rev the motor--what happens? does the nitrous get forced in? nope--it gets sucked in"
yep, thats true, but n20 contains a far higher ammount of oxygen than is in the air you breathe, and I dont think either of us are talking about running a car in a room full of n20, are we? Nitrous uses JETS to push a abnormally(in regards to normal ambient air) high oxygen content gas into the engine, making, depending on the "shot" of nitrous, a cetrain percentage higher oxygen level than would normally be present in the system...wet systems just add extra fuel to compensate for this...
now, a turbo or supercharger generates additional oxygen into the intake chamber by compressing ambient air using either a belt-driven compressor or a exhaust gas driven one,
in all 3 methods, the O2 level in the manifold will be much higher than without the systems, even on an unrestricted engine. thusly, they are "forcing" oxygen into the engine that is not there..
forced induction.
"if they have a turbo and a boost gauge--check their boost gauge--youll rarely see an increase, and if you do--is because of the efficiency increase cuased by lower temps that occured when they sprayed."
duh. nitrous is a great oxidiser and generates lower intake temps. that can lead to an icnrease in turbo efficiency, sure...but it's still a form of forced induction.as to this point:"The nitrous is ingested naturally through an intake tract."I dont see how using a pressurized jet or compressed gas system to deliever something not found otherwise into a intake tract is natural....then again so the compressed air from a turbo is 'ingested' through the intake manifold, albeit at higher pressures.... the point I'm making is that the oxygen content of the n20 isnt "supposed" to be there, more 02=more combustable material for the engine, same as compressing ambient air to shove more oxygen into the chamber.
n20 is forced induction, for all intents and purposes...you';re engine burns oxygen, the gasoline simply allows the chamber to iginite the oxygen, and gets burned in the process.
-chet
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
whiterps13 wrote:i totally agree, if you are talking about a dry system. imo a wet system is a power adder, not forced induction. dry and direct port use force to enter the engine, while wet systems just add nitrous to the gasoline.
no, but thanks for trying!!
the term "wet" is used to describe a nitrous system that also injects fuel along with the N2O.
IT DOES NOT ADD NITROUS TO THE FUEL!! i dont know what crackhead told you that.
it just sprays fuel AND nitrous. the mix is tuned so that there is fuel injected along with the nitrous to equal the amount of oxygen released when the N2O breaks down.
and nitrous IS FORCED INDUCTION because nitrous is not available for the motor to NATURALLY ingest.
IvoryJ30t
you adding a bottle of pressurized nitrous oxide and spraying it into the motor is not a "natural" occurance.
the N2O wouldnt be entering you engine if you didnt install the system.
NOT NATURAL ASPERATION
Nismo_Freak
Force:
The capacity to do work or cause physical change; energy, strength, or active power: the force of an explosion.
The engine's vacuum is the only thing drawing the nitrous charged air into the motor.
FORCED induction... meaning work is required by something to induce it into the motor. IE. something mechanical like a turbocharger or supercharger. Nitrous jets do not FORCE air into the engine. To do so it would have to have positive manifold pressure.
Increasing the amount of oxygen present in the mixture seems to be what Chet is talking about. If thats the case then me driving my car down a mountain face is forced induction because the air suddenly becomes enriched with oxygen the closer to sea level I am. If I put a cold air intake on my car it's forced induction, if I put a piece of ice on my manifold it's forced induction, if a cold gust of wind blows into my engine bay it's forced induction by that logic.
I'm sorry, argue all you want it is NOT forced induction.
