I Didn't block off the opening on the lower right. It's a KA Koyo. The fan clutch is a RB unit and the fan isn't flipped. I notched the core support so I could move the radiator forward. I saw someone post one where they said they didn't have too. No over heating problem at all temps are lower now than it's ever been. Yes my 1st dyno vid is open downpipe, the others I have the exhaust hooked up.placham wrote:Yellow4g63< if you dont mind me asking, whats the spec on the rad your using (KA Koyo?) And the fan shroud is like the one I have, do you block off the opening in the shroud on lower left? I guess most people recess the rad into the rad support. As for the clutch does it matter Ka or Rb? And the fan, did you flip it around, any trimming required? You got any overheating problems?
I just want to ditch the electric fans, and everything associated with it.
Is yours setup that way, I noticed in the thread Carl H. opened up with videos. Thats your S14 with Rb20 right, you posted.
By the way, in that 1st video, your running just downpipe right, cause Rb's seem muffled/quiet with exhaust (at least stock eng.)
Thanks,
Matt
What about running stock KA radiator, is manual trans radiator thicker than auto rad, cause I have auto rad and mine is beat to $hit. I havent had problems with it and electric fans. And noticed the auto rad on a KA S14 is thicker than my S13 KA rad, might upgrade to that one.Yellow4g63 wrote:The koyo is thicker than the stock radiator. I think it would be really close if not touching in your car.
The Auto KA radiator should be thicker because it has the transcooler built into it. When I had my S13 I went from the 5speed one to the Auto Modine radiator from the parts store.placham wrote:What about running stock KA radiator, is manual trans radiator thicker than auto rad, cause I have auto rad and mine is beat to $hit. I havent had problems with it and electric fans. And noticed the auto rad on a KA S14 is thicker than my S13 KA rad, might upgrade to that one.Yellow4g63 wrote:The koyo is thicker than the stock radiator. I think it would be really close if not touching in your car.
And thinnest Koyo rad, the core is even with the end tanks right, unlike stock 240sx plastic tanks where core is thinner than tanks.
Just trimmed my HCR32 fan shroud to my rad besides top hose clearance it fits like a glove.
I have the same setup and problem you had. Can you tell me the details of what fan you used, and if you modified anything (trim fan blades, etc.) It is over 100 degrees outside and I need to run my ac!RRRRB wrote:here are a few pictures of my install, just finished it today...
coolant temps never got above 180 with the AC on!! finally it works
This is the most it would do before I cut it.
