fan on when engine hot?
hahaitzskippy
Car: 88 Nissan Pulsar NX!!
i need to confirm because my friend does not believe me.
1) drive the car until engine is hot.
2) park the car, idling, fan turns on.
3) turn off the engine (engine is NOT running) but left the key in the "on" position.
my question - engine being hot, ecu being on, should the fan be on and running to cool down the radiator?
it does in all my toyota's, my friend's honda's.
my friend in his nissan does not believe me.
can someone confirm?
PEZi
some cars do some cars don't... it has to be an electric fan for one.....
I normally resolve this kind of problem with violence.
hahaitzskippy
PEZi720 wrote:some cars do some cars don't... it has to be an electric fan for one.....
07 g35
Yes it's an electric fan. He also claims that infinti's master mechanic at the nearby dealership confirmed that the fan should not be on
I think he's an idiot and blowing smoke
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
It depends on how the fan is wired. Most of the time, auxiliary electronics like fans can't tell the difference between a car that's "on" and a car that's running. That's why you get a thousand error lights if you just turn the car ton "on" and don't start it. A lot of time A/C is trying to work as well, but obviously can't without the compressor turning.
There's no benefit to the fan running with the engine off, though; there's no coolant flow. You're cooling the radiator but not the engine.
Bottom line:
If the electric fan has power and its thermostat sees that the engine is hotter than a set point, the fan will come on. Fan doesn't care if the car is running or not.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
MinisterofDOOM wrote:It depends on how the fan is wired. Most of the time, auxiliary electronics like fans can't tell the difference between a car that's "on" and a car that's running. That's why you get a thousand error lights if you just turn the car ton "on" and don't start it. A lot of time A/C is trying to work as well, but obviously can't without the compressor turning.
Bottom line:
:werd:
My max will run the fan KOEO, but only if the coolant is hot enough. I have to really flog it to get enough heat in the system. Typically the fan only runs for a handful of seconds at a time, because the cooling system is so efficient.
hahaitzskippy
Bottom line my friends an idiot.
93coupe
Car: crap
hahaitzskippy wrote:Bottom line my friends and idiot.
Pot ---> kettle.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
I giggled. :inoutgay:
Pot ---> kettle.
You do not smoke pot from a kettle.
Urabus GodofTraction
Car: 2002 Subaru WRX Wagon
2004 Suzuki SV650
1988 Toyota Land Cruiser
1994 Honda XR600R
Second Law of Thermodynamics comes into play. Fan on, engine off helps. Not as much as if there was coolant flow, but there certainly is a benefit.
Mr1der
Jesda wrote:I normally resolve this kind of problem with violence.
I'm a fan of violence.
