Fallen hero has RISEN
Jookmasta
man its good to see you back. u were one of the original ka-t'ers that made me go the route i did. always did want to run your red car back in the day lol.
Structure240sx
actually the guy that i bought the motor from is goin ls1
its cool but for a couple thousand jsut for the motor it will get a lil pricy.
he wants it cuz he drifts and wants a big powerband
-ExCesS-
Car: 00 Sentra / 95 240SX
BTW your price range of 7k is that from scratch or do you already have some parts you need?
EDIT: can someone explain boost creep? (yes noob lol)
Structure240sx
included in that price is a manifold setup i still have
normally this would take thousands more but i got a few good deals and know what im doing
boost creep is when boost rises higher than you want
WDRacing
Boost creep happens when the wastegate can't effectivly control the amount of pressure inside the manifold. So the boost level will "creep" up or even spike.
When you retard the timing ALOT you increase the EGT's quite a bit as well. Higher egt's = more manifold pressure = possible boost creep.
There comes a point when timing retard and adding boost become ineffective at a certain octane.
E85 is the answer to that.
Structure240sx
just bought my z32 transmission and kit with 96# injectors will be here next week
i decided while the motor is out to upgrade from the stock size 10mm head studs to 11mm studs. the motor is now at my uncle machine shop waiting to be worked
this motor is super clean should turn out well
nismofly
Car: 89 Nissan 240SX Hatch
your 14 is long gone correct?
1WheelWonder
Car: 1991 Nissan 240sx
Incase I missed something what happened to the built motor in the ole red S14 that was totalled?
Structure240sx
s14 is sitting on cinder blocks behind the shop couple misc things still on it
i had sold pretty much any and every part off the s14 i could to pay for the toys i have had and also a rental property i bought
the old built motor went to a local ka-t guy. for the price i got for it i didnt loose a penny and it had a few miles on it
GEO
Car: 95 240sx KA-T
nice
