Yes, it was.captainluigi wrote:Damn good advice Mike. Kudos.
Could not get accurate reading at harness but when testing at injector got ohm range within factory spec. Appears it was the fuel pump as it went same time as the one in my Frontier a couple days after adding the same fuel additive. I knew the one in my 1995 Q45 was making noise but it only has 80K miles on it. The fuel pump in my Frontier was also expected as the truck has 140K but was making no noise. BTW, the one in the truck is harder to changeout and costs more. You have to remove the fuel tank to get it out. That might not be a bad idea on the Q45 as well but you better make sure that the tank is empty.goody94q45 wrote:It seems improbable that all 8 injectors would go bad at the same time (twice?) and all be ohming the same. I suppose you could be the one out at the far end of the bell curve though. A couple of questions to maybe get you out of this mess:>> Did you ohm at least #1 and #2 FI at the injector to see if you get the same readings?>> Calibrate the voltmeter with a 10 ohm resistor? Replace it's battery recently?>> Battery voltage with engine running?>> ECU codes?>> Been messing with fuel additives again?
Lucas, by any chance?qship96 wrote:What fuel additive are you blaming for destroying 2 fuel pumps?
Read http://www.bobistheoilguy.com and decide for yourself.ppastos wrote:So are all lucas oil products bad or just the oil and fuel additives?
Are we talking about fuel or oil additives? Bob the Oil Dude only talks about oil additives (as far a I read).maxnix wrote:Read http://www.bobistheoilguy.com and decide for yourself.
Lucas is also the God of Immobility too now evidently if you worship long enough.
Economics can always be made political. Facts are the facts.Sanger wrote:
Lets not talk politics. Just stick to the facts.
Are you running for President?
Understand, but that is why they walk off cliffs because they are looking no further thatn the ground that is under their feet.Sanger wrote:Never used their products.
Being an engineer, I always need true facts to come up with true conclusion.
I'm a member over at BITOG and please don't use Lucas products!! I don't feel like finding the posts over there, but take my word! It's a waste of money. If you want a decent fuel injector cleaner, purchase Gumout Regane or Redline S1! The new BG44k formula doesn't cut it.Sanger wrote:
In 1994 the Q's injectors changed. Some members here have had success putting 94 fuel rails in their 90-93 Qs. Your Frontier can handle American gasoline without any trouble. You could probably pour Hawaiian Punch in it if you wanted to.Q45denver wrote:Does anyone know if the injector problems are specific to certain years of Nissans? I am aware of problems with early Q45's and 300ZX TT but it does not appear to be an issue with my 1998 Frontier injectors even though they look similar to the 95Q's?
Just to be on the safe side, no more fuel injector additives for me in any Nissan products. Although I might risk running some through the fuel rails directly.
I don't think the gas I had in the tank had anything to do with the failure, because I purchase it at different stations and locations for the two vehicles.
Thats true but there are still some that have injectors go at least that what i hear from Q45tech.Jesda wrote:
I have personally seen at least two cars with Phase II injector failures - one belonging to the service manager of my local dealership. T3 is seeing failures on the 94-96 Q equal to 90-93 proportionally. So the theory that phase II's will hold up better to E10 fuels vs. phase I injectors isn't panning out.Jesda wrote:In 1994 the Q's injectors changed. Some members here have had success putting 94 fuel rails in their 90-93 Qs. Your Frontier can handle American gasoline without any trouble. You could probably pour Hawaiian Punch in it if you wanted to.
