r34 gtr wrote:Ok, ive got everything together but she wont start. too much fuel or not enough air. it doesnt fire, it just backfires every few seconds and then chokes. crank crank crank crank backfire choke crank crank. thats all i get. any suggestions? im gonna go back and mess with it now, but i figured i would ask.
Probably too much fuel, check your cranking/start up configuration. Dont forget my map was for 370cc and a GT28R. Check you have the spark plug wires connected properly to the right towers.
Post pics of your Trigger Wheel at TDC 2nd mark from the left. Check that the VR sensor wires go positive to positive and negative to negative on the EDIS module.
Also hook the laptop up start Megatune give MS power via the key, check the bottom of MegaTune, then start Cranking it if it says cranking than you have switched power hooked up. I had a issue first time cranking it up where MS didnt get power while cranking.
Modified by The_Chosen_One at 12:54 PM 7/21/2007
