Very slight overbore, 83 and some I will mic them tonight and post the barrel sizes.Chris859 wrote:I might be interested, pending two questions... First off, Any idea if these are stock bore, or oversize(as mentioned above)? And secondly... I wont be able to pay for them untill around the 5th(my next paycheck). Are there any sort of numbers, markings, etc on the underside?
response sent.LongGrain wrote:i will take them, their for a CA18 correct? i can have a money order in the mail tomorrow morning.
totally serius, email me at [email protected] with your shipping info and i will send out that money.
ps. i sent you an email also.
Modified by LongGrain at 10:08 PM 12/26/2006
Modified by LongGrain at 10:24 PM 12/26/2006
have you received my MO yet? i cant imagine its taken longer than this..themadscientist wrote:Without knowing the maker I cannot be sure. The crowns look like OEM so I would expect it come out in the low 8s on compression due to the slightly larger bore. With a cleanup pass on the head it should put it right at stock. The only real way to tell is to install them and take the measurements to figure the CR.
The pistons are 40 tho over. There are 2 overbore sizes available which range from 83.5mm (20 thou over) and 84mm (40 thou over).ca18det240hatch wrote:so the pistons were 10 over or what...
is it safe from a performance aspect to bore them out that far?NUT-CSE wrote:
