Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Mon Nov 20, 2006 10:23 am
That should of been 2 sentences.I meant if the other pump failed it would be the same as the stock one failing.
and
The stock one is more reliable because it is run off the crank shaft. (thought it was electric) But also there are no belts.
I'm not planning to run Huge amounts of power or crazy RPM, so I'll probably just live with it till I paint the car.When I drop the motor, i'll pull out the crank and take it to the machine shop and collar it.
