Thinking i may have to do this.ViolentRunning13 wrote:Cut them out and get over fenders.
well since the weld penetrates all the way through I dont know if it would help but that's what im going to try tomorrow.KA_Pig wrote:Grind the welds down?
Yea on second thought im going to use brian's method and go ape s*** on that b****. I got a vertex kit on the way so if i f*** it up ill just get overfenders.BrianHarte wrote:get a big hammer.
The big hammer is how I roll my fenders.
It is to help the metal expand so you don't get random buckling and dents in the quarter panel. And it does also make it noticeably easier to roll/pull.j-z wrote:when rolling, the heat gun is solely only for the purpose of not cracking the paint, not to heat the metal up to make it easier to bend. if thats the case you need a torch, or stop swingin like a pus$y.
The quarterpanel has definitely been replaced. My dad owns a body shop, so we are going to have to do body work on it. The spot welds are super thick like knots in wood and will not roll (trust me), I believe there is no physical way to roll the lip on it with the knots there. They will have to be drilled out, but we are replacing the quarter panel because the body shop that did this obviously did a s***ty job, the trunk leaks and doesn't line up right. My dad's shop has a really expensive pro spot welder that pretty much replicates factory welds.lonely_coupe wrote:i'm not getting what's hard about rolling these? they look like normal spotwelds, so they are very thick?? you can try drilling them out, to try to weaken the rest of the metal, since it seems that's what making them so strong. if not, try hammering and baseball batting, heat gun, etc....
and if all else fails... cut, smooth, widefender time. hahah.
No doubt.BrianHarte wrote:get a big hammer.
Movingviolation240 wrote:What hammer, all I see is a Poundometer, it's a percision adjustment tool.
The right side is more difficult because of the extra metal reinforcement due to the fuel door. I wouldn't say it's 5x harder though, my right side went faster than my left side...........ThuG LyFe wrote:the pics were pretty unclear for me but from my experience with s14, the right rear is at least 5x harder to bend than the left. you're gonna need a lot of force with a big mallet (not hammer) and heat gun to bend it in. so it's just like that for some reason, the right fender is a lot stronger for some reason.
