boostdesigns.com wrote:Jeff the flange is not a dodge flange it is a garrett 5 bolt flange the larger one actually that they used on the mercedes benz (M24) turbine section i chose this style flange because you haft to use reducers to mate to the smaller 5 bolt flange where as with style flange you can mate the 3" DP directly to the flange without restrcive reducers and still have enough room to be able to actually tighten the bolts from the flange to the turbine section.
Yes. You do need the 2.5"->3" transition to get the pipe on the smaller Ford 5-bolt flange. And even then, I had to get hex-head bolts for the lower and leftmost bolt. You've got the right flange for your setup. I just wanted people to know about that (issue?). I found all these little things out, which, every little thing cost me 3-5 days more downtime from shipping stuff. I think people need to be made aware that if they're buying your kit and customizing it, these extra pieces and work are needed.
Quote » the angle of the DP is to be able to fit the 3 inch DP in there, and clear the steering arm. you are dealing with a top mount manifold not an sr20det lower mount so you run into diffrent placement and angles.[/quote]I know what I'm dealing with. But the logical order of progression for KA-T people is.. intake, exhaust. turbo kit. Cheapest stuff first. The exhaust because it works for any setup later. Every KA-T I know went this route, including myself. So, to get 3" turbo-back exhaust, the only option on the market is a 3" sr20det downpipe to the cat, and the cat-back exhaust. This is why I'm stressing the need to mate with a sr downpipe on my car. Even Enjuku Racing is understanding this, and developing their kit to mate to the sr downipipe.
Quote »these motors are not sr20det engines and dont use the same manifolds as the sr, there for thats why the DP does not line up for an sr exhaust, which does not bother me becouse it was never meant to line up for it, again its not an sr20det.[/quote]See above. We've been over this on KA-T, and we're agreeing to disagree here. I firmly believe that you have or will cost yourself customers by not mating to the sr20det downpipe. It'd take 2 hours to cut one of your downpipes apart, and create the jig for the 2nd version, which many more people could use. All you need is to shorten your downpipe and rotate it ~60*. If I knew what I needed to do to get your pipe to work, I would have made my own. I'm not knocking you on anything, and far be it from me to tell you how to operate a business. I'm not going to compete with you in any way, I'm just trying to inform people what's needed to make this work on a common setup.
Quote »i went with flow in mind knowing i was going to produce the exhaust system to compliment the kit. you see thats why i sell complete kits i know all my pieces work with the others in my design i never guarantee placement or fitment when you try to use parts of my kit with parts of another, it was never meant to be done like that. if you want a guarantee fitment and no issues of flow or performance i suggest you buy the complete kit i can not help when you haft to hack or modify to make it adapt to other pieces that it was not designed around. thanks[/quote]I'm also aware of this, and people should buy a whole kit. But for those of us who made their turbo kit 3 years ago when the options were FMax kit or RevHard manifold and custom kit... I, like ~50% of KA-T owners, went with the RevHard. Your manifold came out, and I wanted to update/upgrade, and I did. I'm really happy with the manifold. And once again, I'm not knocking anything you've done or you're doing. Just stating what mods need to be done to work with your downpipe or your exhaust. If you'd like, feel free to copy-paste this stuff to your website to inform people. Just give me credit for my time and money going into this research.
Also, WDRacing is correct. The 240sx/silvia use the same hangars. On a S14, the front cat (just past the stock header) is where the sr turbo sat. The 2nd cat (it's hollow, and fake) is where, in Japan, their catalytic convertor was. So the sr20det downpipe.. with a slight flange angle rotation, can bolt to the stock header and connect to the fake-cat, eliminating the real one, and that restrictive 2" crimp-bent front pipe. Then all standard cat-backs bolt up from there. SR20DET silvias and KA24DE 240sx's share all exhaust mounts and hangar locations. So.. saying that the KA shares nothing with an SR is incorrect. Which again, makes the sr20det downpipe such a good way to get 3" turbo-back exhaust on a custom kit. Even MaxType 240, with his full FMax kit.. cut apart their downpipe to mate it with a 3" sr20det downpipe, because FMax was only 2.5".-Jeff
