pouncer11 »
https://forums.nicoclub.com/pouncer11-u94289.html
Wed Apr 16, 2008 7:47 am
whats the difference on the 94s that i should look out for with the manual and btw im calling the infiniti shop now to see if theyve replaced the chain guides and if theyll do it for 1200. im about to run the car into a lake.
i was told by Infiniti of Dayton that my car was checked and repaired for the timing guide a long time ago. so im safe on that aspect, i jacked the car up, took a look at the exhaust and found out the right side has been repaired up in the front, the same place the left side needs it, there was a weld or something holding the pipe to the car and it looks to be rusted off, i used some muffler epoxy and a coffee can section to hold it down (works great for now) till i fix the injector. 50 bucks to fix muffler btw.
i would suggest that if youre not the first owner to check with the dealer's service dept about the history. they know where every spec of dust in my car is haha.
Modified by pouncer11 at 9:33 PM 4/16/2008
