Exhaust Issues??
OneHotPathy
Car: 01 Nissan Pathfinder
Anyone else out there having issues with there exhaust? I just replaced my oem exhaust with a 30 series flowmaster and upgraded to 2 1/2 inch piping from the cats and a 3 inch piping after the muffler itself. NOW for the issue.... Over the last 6 months ive managed to blow out 2 banks in the Cats! Any else had this problem? Is it the new piping or just wear and tear??thanks guys.
LiquidLunch
Car: 02 Pathfinder
Were the resonators replaced also or was it from the midpipes back?
They only way I could see the new exhaust blowing out the cats is if the exhaust flow from the new muffler was really restricted. You never know, the new muffler could be plugged. Otherwise, chalk it up to dumb luck.
OneHotPathy
I took the resonator right off..... bad thing?
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
When you changed your O2 sensors did you take it afterwards to the dealer to have the ECM reprogrammed? If not then supposedly you will continue to burn up the back O2s because they heat up too quickly.
There's a thread I remember searching on that had the specifics of this problem. Here's a thread that talks about it briefly.
zerothread/281901
Good luck.
