I'm serious. I wouldn't be using any dryer vent. I would use 3in SS pipe from a local company.qship96 wrote:go to home depot,buy plastic dryer vent flexible pipe,and use that-or better yet,remove headers and allow exhaust to exit engine block,and remove hood to allow for some underhood ventillation!
Wrongo, Bunky!elwesso wrote:Like Q45tech said, modifying the exhaust at the rear is the most cost effective mod you can do..
Dont worry, Jesda will give you a hug...Dennis wrote:Working with the rear muffler assembly is the most cost effective and weight saving mod you can make on a Q.
Find a dual in dual out straight thru Dynomax ULTRAFLOW.......the quiestest lowest backpressure [you can see straight thru each section] muffler made.Both the corporate Q have this ULTRAFLOW muffler held in place by Chrysler oval bands onto which have been welded the 4 oem mounting brackets/ears so it it supported in oem fashion .......
...... We have retrofitted and designed systems for dozens of Q45.
But there was was negligible performance gain for big bucks, Bunky! Some weight saving at the expense of durability, sure. That's not performance in my book. Else, you would junk the whole thing and be done with it.elwesso wrote:Was dennis kidding in this thread?? Huhh bunky????
http://www.nicoclub.com/zerothread?id=64804
Wasn't that your statement, not how much one can spend for the hell of it?Q45tech wrote:VERY Loud exhausts might be good for 3-4lb/ft more.
The exhaust system and intake are very low restriction so little is to be gained.
More fun is to beat the new 2002 Q! My 231k 90 with stock air box, stock new exhaust [from a 95 after my custom system rusted through
Does this imply anything about performance gains??? I didnt mean to...Wes wrote:Modifying the exhaust at the rear is the most cost effective mod you can do..
Actually, in that thread he mentioned he didnt like the vibrations and other things like that it gave, so he took it off for more quietness.. But who cares..
Now about that group hug.....
Q45tech wrote:More fun is to beat the new 2002 Q! My 231k 90 with stock air box, stock new exhaust [from a 95 after my custom system rusted through]...
But he never has said that there were any significant gains in modifying the exhaust, even with the attendant unbearable noise and vibrations of no resonators or mufflers. He merely said it was a way to remove some weight, and by result, limit the systems durability.Jesda wrote: But this thread is about performance, and if Dennis says so, I guess its true.
Damned, owned again!Q45tech wrote:YEP, I gave up 0.1 second for peace and quiet of mind [almost new oem 95 system - went by our muffler shop a few years ago and what were they taking off to throw away but a less than 1 year old [replaced by insurance company] entire oem Q exhaust...........$20 cash and my old system was trash and the newish one on my Q.......what a deal!
I've had so many lucky Q parts days ------saving thousands.
Were you talking to me? If so, I have read the things that he posted.AZhitman wrote:You've obviously not read a thing Dennis has said.
All the knowledge is here, you just have to read.
