exhaust and coolant?
DjSpecter
Car: 1993 nissan 240sx coupe SE
Um..not to sure about this but I did some research and nothing. But should there be coolant comming out from the exhaust? cause i smelled it and its green and it smells like antifreze. is this normal?
Axel Grungy
Car: 2001 G20 5spd
no not at all, youve prolly blown a head gasket. is it not billowing white smoke??
DjSpecter
nope no smoke. Im still in the process of trying to start it. but its green and deffently coolant.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Your headgasket is toast. Keep cranking with coolant in the cylinders and sooner or later you will destroy your piston rings as well.
cmoody2006
Car: 1993 Nissan 240sx vert
yep what they said! Don't waist your time rip that bish apart and replace it
DjSpecter
ok cool ill get down on it.
