actually some people directed me to some links and apparently its been done. check for yourself. by the looks of it, thats an s14 due to the ruca. i still have freaken 4 bolt hubspntang wrote:the only thing u can use off the evo or sti is the front brembo calipers...and even those needs special brackets...so i would try and sell those so u have money for something else
can someone tell me how this works? its only to engage the parking brake right? i mean can i just make a braket that allows me to mount the calipers and use evo rotors (have the rotor redrilled to match 4 lug)StricNyne wrote:just dont use cable and get a seperate lever for rea4 calipers, google the cnc staging brake, or hell even google z32 staging brake and u will see some cool setups, i even think the d2 hydrolic ebrake will work for front and rear calipers, that way u get rid of cables altogeather
Modified by StricNyne at 4:56 AM 8/1/2008
dude,the car posted above is MY car.....you will LOVE the EVO brakes....just rember to get some SS lines (evo SS lines Are DIRECT BOLT ON) And ENDLESS Stock Replacment Pads (~150-170$)tEknoS13 wrote:
If you want to mount them on your car (s14/s13) you need an adapter plate for the front and the rears....
For the front you can find it on Zilvia.net serach there for "check out my big brakes" and you will find the thread...go to page 7 and you will find a sketch that you must print and go to any machin shop and let them machin it for you.....
as for the rear...you will need adpter plate for the rear caliper to fit....and you will lose the E-brake b/c the inner rotor dimeter will not fit over the Z32 drum/e-brake setup....
alot of guys swaped EVO VII/VIII/IX Front brakes And for the rear go with Z32 Rear brakes (rotor AND caliper b/c the Z32 rear piston dimeter is 40mm Vs the EVO 35mm piston....
JhonC (member on zilvia.net) said with the Z32 BMC he felt the rear brakes are better with Z32 Vs the STI / EVO brembo....
My setup,
EVO IX CaliperEndless CERAMIC PadsEndless SS linesSTOCK BMCSTOCK rear brakes
Will upgrade to Z32 rear's in the next 2-3 weeks...
Sure hope this help,
Kind Regards,
Ali
EDIT :
If need help...just ask son....
Modified by Ali 556 at 12:39 PM 8/2/2008
WTF ! I just gave you the zilvia link with the whole process including the z06 calipers.tEknoS13 wrote:
SoSideways wrote:Front: STi Brembo calipers / Evo rotorsRear: STi Brembo calipers / Evo rotorsBrake lines: Brembo brake lines for STi Brembos
maybe you should try your self to double checkKrinkov wrote:thanks, but to add to that EVO calipers will work in the front but the rears dont bolt up, only the STI calipers bolt up in the rear
oh ok u kinda messed up. i was reffering to that dude stricKnyne since he told me about a hydraulic handbrake.xpicer wrote:
Are you building a "draft" car....? NO...so go with the Z32 rear e-brake/drum setup and you will win...tEknoS13 wrote:
anyway i still dont understand howu are working the whole rear assembly. well i get the fact that u have to get some special brakets to put up the calipers, lines are direct fit,... and u said u will loose the z32 drum. so how are you running ur parking brake??? did u get that secondary Wilwood caliper? because i was just thinking about using a hydraulic handbrake strictly for ebraking.
x1000tEknoS13 wrote:nice. i just sold my evo calipers. i will stick with 300zx rears instead since i already have the front
