davidricardo86 »
https://forums.nicoclub.com/davidricardo86-u32537.html
Thu Apr 09, 2009 7:11 am
A while back i bought a euro harness from Ragenasian too. I went and installed it thinking everything would be fine but found out theres more work cut out then i had expected. It is not plug and play.
The harness that I bought from Ragenasian was for the engine, lower engine harness, and engine bay harness which included connectors for the lights, relays, fuse box, etc. and any other accessory under the hood. It was all meant for a LHD German 200sx IIRC so some plugs/connectors/components were a little different.
I've spent good amount of time now figuring out how the power supply, charging system, headlights, corner lights, horn, tail lights, wiper washer and interior instrumentation lamps are suppose to be. The problem is that some of the wires are in different pin or connector locations even though my 240SX and the Euro 200SX are both LHD. Right now I'm stuck at the Super Multiple Junction (big white connector under driver side leading from the engine bay harness into the Main interior harness ) as this is one of the points that most wires have to go through.
The CA harness did not have cruise control, at least it does not appear that way from the harness i have. The KA/240sx harness did have cruise control. Also the Euro CA harness does not have wiring for the butterfly actuator system incorporated to the Japanese CA harness. Another thing about the Euro harness I that i found out was different was the Ignition Module/Ignitor location. On some of the Euro harnesses its located on the engine bay harness, not on the engine harness itself like the JDM CA harness. On other Euro harnesses its part of the Engine harness like the JDM CA harness. Another difference i found out was that the MAF sensor connector is different. The JDM CA uses a four wire MAF sensor and the EDM CA uses a three wire MAF sensor. The FSM states that the four wire MAF sensor is for the CA without a catalytic converter.
These are some of the differences i found and i know theres some more that i might have missed. I took notes and mapped out the differences in the wiring using wiring diagrams and the FSM which seemed to be the easiest way. I'm still not done converting the harnesses but hope to have it finished before summer. Sometimes i wonder why i put myself through this!?
