essential mods? for more HP and suspension and brakes.
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
As for ESSENTIAL MODS:
=Tokico HP Shocks
=Brake Upgrades - My most favored mod for the Q. The Q has great braking power but they also fade fairly quickly.
Other mods:
=Nice Wheels
=Air Intake - Great sound! Don't expect any gains... personally I might take mine off, its annoying.
=Exhaust - paired to a V8... Don't expect any gains with a legal system
qship96
Car: 1996 Infiniti Q45
Well, you got 1 right, the Tokiko shocks. All others are downgrades
ddrumman
Car: 08 FX35 39,000 mi, 07 G35 55,500 mi, 72 MGB
Whatever is in my sig minus the wheels and tires. You can do 18s if you want. Also, rehabilitate the suspension to as new, plus all rubber parts everywhere.
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
NightRiderQ45 wrote:
I purchased these bulbs Jan 07 before I moved to Oklahoma and had to replace them in December . After reading on different forums concerning these bulbs, many agree that SS don't last long. Maybe Sylvania fixed the problem causing the SS to die quickly and called them Ultra SS bulbs + extra $10! Marketing I tell ya.
Oh, I didn't touch the bulb with my bare hands. Just need to throw that in.
I've had to replace 4 of mine in the last 2 years. Always the low beam, since my high beams almost never get used. I don't pay for new bulbs, because they come with a 1 year replacement warranty. Each time a bulb burns, I bring in the old bulb + receipt and I get a new bulb in exchange.
meandmyq45
Car: infiniti q45
I THINK I'M LOST
moshmoshi
Car: Q45
Are coilsover have any advantages over just the springs and shocks? Iknow it will get the lower height I want
moshmoshi
Car: Q45
Hey QSIGUY, how is the STS turbo running? My cousin has their kit for hisExplorer but it's sitting in the garage. I'm thinking about getting it and tryto get it to work with the Q
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Haitian_King wrote:
If the $2k Brembo setup is needed, it may be safe to assume that the driver drives WAY too fast (for public roads) or takes his Q on a race course.
Try about $5K front and rear, parts only.
No one that I recall has done the FGY33 front upgrade, but a couple have done the rear FGY33/J30 rear vented upgrade. Don't know if the front calipers will plug-in at the correct offset.
Haitian_King
Car: 1992 Black Infiniti Q45 /w TCS
1995 Black Infiniti Q45
Didn't realize he was talking about an FY33. I was referencing the price for the G50 Brembo kit.
T45
Car: King Kong powered Z32
If Z rotors will fit the Q and vice versa then it's safe to assume that all Z brakes will be interchangable with little to no mods. There are a ton of brake upgrades for the Z starting around $200. For about 500 you can upgrade to larger rotors with the necessary adapters for the caliper and then get some Z calipers and SS lines and you'll have a pretty good system.
I think...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Haitian_King wrote:I was referencing the price for the G50 Brembo kit.
That is just the front, not the big rotors and calipers for both ends.
Haitian_King
$4k for brakes?
Why would someone deal with that? Jesus. What if they were installed one pair at a time? Aside from uneven wear between the two sets, what if the front were the Big Brembos and the rears were stock? Is that even possible?
Q45tech
Getting things out of balance is the major problem inthat factory brake bias is tough when you change anything: tires, pads much less major brake components.
Oem was near perfect in that they wore the pads amost equally at 22k +- 2k front and rear.................due to using the the rears more than most cars, they gained 3-5 even 10 feet compared to others of that era.
In a panic stop ABS [activation] just lengthens the stopping distances to preserve tires against flat spotting.
A simple panic stop from 60 will tell you by how many ABS activations you have how badly out of balance you have made the system................use an electronic counter to count the cycles and loacations rear vs front.
Every braked modded car I've driven was worse than just a perfect oem system...............in panic stopping cold or hot from 80. But I haven't driven them all!
Always good to review what they tried on 350z and the dismal results considering initial and future cost:http://www.zeckhausen.com/testing_brakes.htm
Best was 4 feet improvement out of 200 feet at 80> zero
