There aren't many negatives to wind power.
It's basically siting issues. Almost the entire Great Plains provides enough wind to run a wind farm. The land is relatively cheap, and the towers don't disturb the ecology. There are some objections about migratory flight paths, but the farms really don't cover much ground and are in groups at 300 ft high or so - pretty obvious obstruction. The main thing is transmission lines to connect them to the national grid. Those cost around $500,000 per mile for the big trunk lines, and $250,000/mile for branch lines. So when you find a good spot to locate the farm, you have to consider how far it is from the nearest line capable of taking the power. The other big problem, as you point out, is how to store the power, since it isn't steady or reliable.
I love the way wind can become a distributed power source. An average household requires about 4KW of power, so a 1.5 MW tower can supply enough electricity for 200 homes at a conservative 26% wind efficiency. You can put about 40 1.5MW towers on each square mile. So 640 acres of land can supply 8000 homes, and all but 2% of that land can still be used for grazing or farming. Puts new meaning into farming, eh? Farm the land, farm the wind. All you need is the transmission line and a substation. The entire State of ND has only 300,000 households. That would only require 30 farms of 100 towers each. It's about $10,000 per household - not a bad capital cost. I have this wild idea (never gonna happen, but just imagine) - picture every farm, or even just lots of farms, with a barn, a silo, and a 1.5MW wind tower. Widely distributed power generation. What if the State or Feds offered a Gov't-backed loan program to get them going? Beats the efficiencies of ethanol, I bet. That's some Populist Socialism I could support.
All we need are two things: Transmission lines and storage. Storage really only becomes an issue if you intend to rely solely or heavily on wind power (no one is proposing that), otherwise it can be distributed across the grid and used elsewhere to supplement baseload generation. And if you can diversify the farms widely enough across the country, there's wind blowing somewhere almost all the time - better baseload reliability.
Here's a wind energy map of the USA. Look at how much of the Plains is rated fair to excellent(orange, pink purple - the pdf file has more detail).
http://www.eere.energy.gov/win...s.asp
And here's a good forum thread I ran across:
http://greenhome.huddler.com/f...es=27
