96Qowner wrote:So, I wonder what the initial construction costs are for nuclear. I know that it can amortized over a VERY long time, and I actually love nuclear energy, but if the cost is too very much higher than cutting-edge coal production (complete with CO2 sequestration), I'd be hesitant to dump too many bucks into it. Nuclear freaks people out. It might be a nightmare to try to construct many more in the USA - protests, redesigns, years-long authorization procedures, etc. It's a shame.
For the cost of a nuclear plant, you might be able to build 5 times the capacity through wind, perhaps making up for the unreliability of the generation.
(If we could just store it somewhere - recently read about a guy proposing kinetic storage by pumping water into hydroelectric reservoirs.)
Okay.. well.. this is going to freak you out.. a commercial nuclear power plant will cost from 1 to 20 billion dollars to build.
Now, keep in mind, this can factor in a GREAT number of things. Location, size, type, and fuel.
Reactors can essentially keep on running forever. The fuel can run between 10 to 15 years, and then you replace it with unspent fuel. You can send the spent fuel to a research facility or a disposal facility, whichever. If it gets sent to a research facility, it can actually be turned back into fissile material again and be used quite probably 3 or 4 times over. We do have a number of Breeder reactors, but the problem with Pu is that it's just crap for sustaining power for energy, although we do have a few labs that have experimental reactors that can recreate Uranium, however, it's the unstable fast U238 and heavy U239, not the steady U237 that we generally tend to want for the reactors. When U breaks down, it can break down into a number of things, but it will most probably do so as Xe and Kr which are gases, which will rapidly Beta decay into Cs and Rb which are solids, which means that we could try to do fusion.. but, we all know that fusion at our level is a fruitless endeavor. So, Uranium exists naturally in all substances, same with Krypton and Plutonium and Xenon and Potassium and Iodine and Radon, which are our main culprits for ionizing radiation from surrounding materials. But, the largest stores of Uranium have been found in the Kentucky/Tennessee Valley areas and in the Australia flats. Mining and purification of Uranium is a very intricate and costly process, but yielding it is a very lucrative business endeavor.
All Nuclear Power plants must have a water source, there must be a heat sink. All power plants, like coal which actually burn the coal, must use a heat sink. The problem with coal, is that the emissions are extremely toxic. And, the problem with putting the emissions underground is that we are not yet sure if they are actually contaminating anything in the ground yet either. The subterfuge method is very costly, and it reduces the output of coal to a fraction of what the plant should be. The filters and vents that the emissions must go through in order to be scrubbed before going underground reduce the output so drastically, that I know Duke Energy Corporation is considering revising the plant they have in Vigo County, IN. Coal Gasification hasn't been used long enough to determine the effects on the environment, we have yet to see what it will do, though.
The type is also a big factor. You can build a PWR or BWR, Westinghouse and GE (these are the big two), 500, 1000, 1500. To date, the largest reactor is a 1600 MWe reactor being built in Finland between a french and german company. Let me give you a reference point.. I can't exactly tell you how big my reactor was.. but.. let's just say it was around.. 0.5 x 1000.. or aroundish that number, kinda close, not exactly, MWe. My ship has 2 reactors.. now, these reactors stand 3 stories tall.. they can fit a car inside the vessel, comfortably. It would take approximately 15 to 20 people touching fingertip to fingertip to go around the entire vessel. You could sit inside the piping. Everything for this stuff, is just that big. So, imagine what something 3 times the size would be like? Say, Chernobyl? The reactor (RX for short) vessel head (by the way, the specifications for sealing a vessel head onto a RX are 4,000,000 ftlbs torque per closure bolt minimum, up to 10,000,000; that's for the DoE standards, there are usually anywhere from 30 to 150 closures on a RX vessel head, do the math, that's a lot of pressure to pop off) weighs around 1000 tons and she's on a ledge. They left the sarcophagus open to the air to allow for heat to dissipate for the radioactive decay, well, if the vessel head ever falls, that's a lot of fallout that's going to get re-released into the atmosphere again. Stupid stupid stupid.
The last thing really is the cost of running it over time. Once it's built, it has minimal costs to keep it running. It's virtually self-sustaining. The reason, I suppose, that people are so afraid of Nuclear Power, is that they're just uniformed. I have actually been to Yucca Mountain (a privileged life I lead as a child, yes) and to the facilities at INL and Goose Creek, SC. I just wish that people could see how well the material is actually kept. The facilities are maintained so well. Hell, when I needed a cat nap, I would go lock myself into the RAM storage area onboard ship and take a nap, RAM is so comfortable. Anyway, the point is, 99% of it isn't even radioactive, it's just paper that "might" have been in contact with something that "could" have contaminants in it. Most of the fuel, though, is kept so very tightly, it'll just decay away and become part of the earth's composition again like it was before.
